03 4.6l wont turn over or crank
64dodge
alabama
My wife stopped at station to get gas Thursday, turned it off and it wouldn't start or turn over when she got back in. When I got there every thing seemed to work, lights were bright so didn't think battery was dead but jumped it anyway, still nothing. Pulled gear lever to low put back in park still not turn over, put in neutral still nothing. Pulled home and jumped starter from battery lug to solenoid lug and it works great, spins engine over fast. Turned switch on jumped starter and wouldn't crank, just spin over no start. So its not firing plugs and or injectors either. I can hear fuel pump running. Pulled and checked every fuse and relay all were good. Hooked up laptop with obdii code reader and would not connect to read codes, just like switch was off. Found this thread http://www.expeditionforum.com/f41/03-no-crank-no-clicking-22188/index3.html
checked pin 85 & 86 no ground or power on relay1. So does this mean the PCM is dead.
Is there a way to test PCM?
stamp11127
Temple, Georgia
I'm checking the wiring manual, but if there isn't power on the relay that means a break in the wire or blown fuses.
Check the following fuses:
F1.101
F1.102
F1.5
PCM Power Relay
Check fuses with a test light or dvm - not visual inspections.
And the standard - is the theft light blinking fast?
B
bedrck46
check to see if the front cigar lighter works
if not the fuse is blown #41 20A
that fuse also is the power for the OBD II port
64dodge
alabama
F1.101
F1.102
F1.5
Are these fuses in right kick panel?
PCM Power Relay
I checked all relays in right kick panel. Hooked + - side of coil to battery.
When coil inergized contacts made.
Used fluke dvm.
No its blinking the same.
B
bedrck46
yes they are in the right kick panel
do you have the owners manual??
stamp11127
Temple, Georgia
PCM relay is in the central junction box with the other fuses - F1.*** - location is "under dash RH side" Looks more like the kick panel to me in the drawing.
Check for power on the load side of the pcm relay, usually pin 30. Some may wire it to pin 87 or 87a. Even though you hear a click when you apply power to the coil, you don't know if the contacts are good on the load side or if that side has power.
Did you check fuses for power with the ign in the run position and at both test points on each fuse?
64dodge
alabama
I have unhooked the battery now odo in instrument panel shows no mileage just
64dodge
alabama
Has 12v on pin 30. I can jumper pin 30 to pin 87 in fuse panel and the starter will spin engine but not crank with switch in run or start position.
I checked all relays in right kick panel. Took everyone out Hooked + - side of coil to battery. When coil inergized contacts pin 30 & 87 made tested with fluke on ohms .
No I just checked continuity of fuses.
B
bedrck46
stamp ford started doing that with the 03 model year
R301 Trailer tow
back-up lamp
relay
Trailer tow 7–wire connector
(back-up lamps)
R302 Speed control
relay
Speed control servo
R303 Fuel pump relay Fuel pump shut-off switch, PCM
(fuel pump monitor), Fuel pump
R304 Battery saver
relay
Roof rail lamps, Vanity mirror
lamps, Map/Dome lamp, Glove box
lamp, Cargo area lamp, Outside
mirror puddle lamps, Instrument
cluster (interior lamps)
R305 Horn relay Dual note horn
* Mini Fuses ** Maxi Fuses
Note: Relays R301–R305 are not serviceable components; see your
dealer or a qualified technician for assistance.
stamp11127
Temple, Georgia
1) I hope we are talking about the pcm relay - upper right hand corner of central junction box. If you jump that can you connect the code reader to the pcm and communicate?
2) Make sure the fuses have 12v on both sides with ign in run position.
3) pm me your email address
4) Just for giggles, if you can check fuel pressure it would be nice to know what the cranking pressure is. We need to establish if you have more than one failure occurring.
stamp11127
Temple, Georgia
Thanks for the info bedrck - relays not serviceable my ass.
Give me a good shot of the pc board and an internet connection, I will find the relays. If they can solder them on there, I can desolder them....
stamp11127
Temple, Georgia
64Dodge - this problem has cropped up on here before with no real solution other than it started working again after the fuse block was removed and inspected for burn marks on the pc board. (Thanks to bdrck46 for that info).
I also vaguely remember something about areas burning on the board.
You may try unplugging the fuse block, taking covers off, inspecting and plugging it back in.
B
bedrck46
64dodge you can download a copy of the owners manual by going to
owner.ford.com
B
bedrck46
fuses on the wiring prints are listed as F1.*** but in the owners they are listed as Fxxx so fuse F1.101 would be the same as F101
