2000 Expedition, can't find this coolant leak
Manlavi95
PCB, FL
It's gotten gradually worse since I got it June of last year. It's not coming from the heater hoses, it's not coming from the intake gaskets on account of I just replaced them... I just know it's coming from the passenger side of the engine in a spot where I clearly can't see. It leaks down the same heatshield as the AC condensation, but it can't be the heater core since it's running down the block. I feel like it's a freeze plug. What problem areas are there on the passenger side of the engine other than heater hoses?
stamp11127
Temple, Georgia
Head gasket or cracked block or cerebellum. Use a mechanics mirror to inspect.
Manlavi95
Manlavi95
PCB, FL
Cerebellum? Don't insult me like that!
I'm just kidding. I'm thinking it's somewhere on the rear heater hose in between the top and the bottom where I can't see it. I wish I had a mirror
ExplorerTom
Colorado
It's coming off the back of the block? While parked on level ground?
You said you changed the intake manifold gaskets. My intake manifold cracked and was leaking coolant. In my case, changing the gaskets wouldn't have solved the problem. Could yours be cracked as well?
Manlavi95
Manlavi95
PCB, FL
I was actually thinking it may be this. That or the freeze plug
