Check your trailing arms. They rust out. Ford should of recalled them. Listen for a clunk, going between D and R.
I believe if you cut the brown wire it is the same as pulling the FUse. Correct me any on here. If your tires are the issue rub your hands on them and check for cupping.Lots of great advice...gonna bring it in to the shop here soon. After putting the 104 fuse back in (now several days) but brown wire cut I still have no more bucking/hesitation but the vibration continues. Vibration seems to get worse as the car warms up....maybe tire(s) are warming up through road use and unbalancing ( I don't have the right terminology)? Could the u joints warm up and cause worse vibration hot?
I am going to check my trailing arms as well. Worn ones could cause steady vibration?
Which fuse? 104?Pull the fuse
ThanksYes pull the fuse #104 underhood I pull mine during the summer months save some fuel. For the brown wire Mod there are plenty of videos on youtube. Google it
Thank you RunningonExpy for coming back and letting us know.My bet is drive train. Perhaps drive shaft or u joints.
