Kryo-Genik
Ok I've got power to the unit and it tests fine and will play a dvd without issue. However I have NO sound to my headphone Jack's on the back of my center console. And I need to know what wires I need to jump/splice/connect to make the plugs work
I found the following text to help me jump things....but none of these wires make sense as I have no "orange" or "pink" wires in my truck. I'll gladly put together q how to guide once I'm done here provided I can get the wires correct and spliced for the group. I'll even show how I fabricate the plug qnd everything.
"You need to pull the DVD down and access the gray plug behind it . Connect the following Pin 7 red to pin 5 white Pin 17 white to pin 15 green Pin 8 orange to pin 6 red Pin 18 pink to pin 16 black. Use a short piece of wire and jump them together. This will make the headphones work."
I've pulled apart my center console, dash and overhead looking for wires that match these colors to no avail. Either I'm blind or my truck is screwy. Please help me here what do I gotta splice to make the head phone Jack's work?
At my dash is a square block style plug. With wires...right to left if looking directly at the red face of the connector
First row Green, white, black, red, black, open, blue w red stripe
Middle row right to left
Open, open, open, open, gray w black stripe
Bottom row right to left
Tan (maybe a light orange?), blue with pink stripe, green w black stripe (power to unit), open, open, open, blue
Then for my overhead dvd player I have the following. Looking at gray plug with clip down left to right
First row
Black, green, black w green stripe, black, tan (or light orange maybe?), blue w pink stripe
Second row
Red,white,black,blue w red stripe, green w black stripe, red w yellow stripe
Then inside the console the headphones are part of a larger circuit board setup not a direct wire as such. But my wires looking from the side of the plug with the clip are
Bottom row
Pinkish w yellow stripe, gray w blue stripe, black w purple stripe, orange w red stripe, open, black with green stripe (or green with black stripe),black, blue with red stripe
Top row
Tarnish w green stripe, tarnish w white stripe,open, blue w red stripe, tannish,open, black w green stripe(or green w black stripe), red w yellow stripe.
First row
Second row
Bottom row
Top row
