2005 Expedition AC Program Fix
commish62
Atlanta
Wanted to share this with everyone in case it helps.
Started the Expedition at lunch and accidentally ran through the mode selections on the A/C very fast. After that, the A/C started cycling on for 5 secs or so and then back off for 5 minutes or so. This caused no real A/C to work. After a lot of internet research, I found the only clue might be a confused program or an error in the PCM. I removed fuse #5 in the fuse box for a few minutes to reset the PCM and the A/C is back to normal.
Wanted to share this with everyone in case someone else had an odd A/C problem like this one.
