Earnest E Dever
I have a 05 expedition with a vibration. I have balanced all 4 tires, checked all the ujoints,checked all the axle shafts, and found nothing. I did notice whale on the lift it seems the front hubs are not disconnecting? Whale on the lift I can turn either front wheel and the front shaft turns with it in 2wd I believe the hubs are not disconnecting? Are they vacuum? It appears to be a vacuum hose in the top back of the hub? If so is there a vacuum pump? Or is it pulling vacuum off the motor and is there a fuse or relay to make it work
Sorry for the long post thanks in advanced
