2015 Ford Expedition clogged fresh air intake
Iamsam1117
California
Good morning gents, I'm getting a whistling/clogged sound when running in non recirculation mode. In previous cars it was an easy fix. However I've noticed the 2015 doesn't have a cabin filter and cannot locate the outside air intake. Any help finding the path to remove the clog?
Sgt Darkness
East Tennessee
Where is the clogged sound coming from? I assume it’s coming from one of your a/c vents but not a good idea to assume anything. Can you record the sound it’s making on your cell? Did it just start or has it been going on for awhile?
Iamsam1117
Iamsam1117
California
So basically it makes it on full air. Like a whistling noise. Being an a/c tech it sounds like what would be a clogged filter. However if you push the return air button it disappears. Could also be a busted fresh air damper I suppose too. I only have the electrical manual for the car.
Plati
If all else fails would you consider a big shop vac sucking on an offending vent and then reversing and blowing? Might disrupt the issue. Just a pathetic workaround I guess. I refer to my big shop vac as the suck and blow machine. Lol
99WhiteC5Coupe
I bought a new 2015 Expedition Limited 4x4. During one service visit, the Ford dealer said there was a computer update for the HVAC controller, and it was performed.
After the update - when I use the a/c on high, including the rear a/c on any speed, I now get a whistling sound from the system. If I switch to recirculation mode, the sound goes away. If I get the whistling sound, it will also go away if I slightly open the rear, tilt-out windows.
I was irritated the dealer performed an update, which only caused a problem. On return visits, the advisor said they could not “undo” the update - and there were no additional updates.
I removed the LR taillight assembly to ensure the vent flap fitting was not clogged, and it wasn’t.
I’m stumped.
Hamfisted
Ft Lauderdale
It's your truck trying to tell you to just run it in recirc mode, and not be constantly trying to cool down hot outside air.
RobK
Wisconsin
Did you ever find out what was causing this issue? I am having the same problem.
