Mxer0022
How are you liking the drilled and slotted rotors? I put some slotted on our '16 and they are horribly loud. Like to the point that I ordered new brakes to replace them even though we should be getting our '22 in april.
When I changed my OEM pads out at 33K the rear pads were almost gone. Fronts were not bad. When you search the auto websites the OEM pads for these are ceramic. I put semi-metallic pads all around at first but, had an issue with a stuck against the rotor always front inner pad & switched the fronts with ceramic. I am loving these Elite ceramic pads I picked up at auto zone. The rear semi-metallic pads are doing fine, just loads of brake dust.
Why is it that most are finding heavy wear on the rears and not the front?I had purchased pads a few months ago, planning on replacing them when I rotated the tires... but AutoZone sent me the wrong parts (a deadbolt in place of the rear pads).
They eventually got me the right pads, but I already had it all back together by then so I put them off... too long. One of my rear pads wore past the pad material and started to chew the rotor The rear pads (that weren't completely missing) were all very worn, the front pads still had a lot of life left in them... but they (and their rotors) all got replaced anyways.
I ordered a new set of PowerStop rotors (blanks) and installed all the new stuff yesterday... stops great now! I probably looked like a lunatic breaking them in outside my neighborhood, per PowerStop I did a few dozen 30mph-5mph runs on my way to pick up dinner... at least that's done now.
My theory is the small pad area on the rears.Why is it that most are finding heavy wear on the rears and not the front?
Lots of questions about why rears are wearing faster than fronts on these vehicles. Every vehicle/driver/route situation will be different; but, the traction assist and yaw control on these vehicles involves the rear brakes. My guess is that is a significant contributor to rear pad wear. Historically OEM's attempt to strike a wear balance between front and rear. My experience with Ford rear drive/4wd vehicles with traction assist and yaw control is that the rears go before the fronts. Some of the posts above talk about two footed drivers, implying that driving style may wear brakes faster; well, with traction assist and yaw control, the computer is two footing it for you on the rear wheels only.
Lots of plugs for Autozone Premium Ceramics on above posts. Add me to that list. I have them on my 2007 F150 and 2012 GT500, and love them. Both vehicles have cryo-cooled Centric rotors. The 2007 F150 went over 80,000 on the first set of Autozone Premium Ceramics. The second set has 60,000, the Rotors have 140,000 with one turning, still stops way better than when it was new. I would have never believed that kind of brake life possible on that truck with the people I have driving it.
