4th Gen Expy FORScan Modifications
scottdm
Western PA
FYI, I tried disabling ASS (auto start/stop) on a 2019 Expedition Ltd Max that was manufactured just a few weeks ago, and found that doing so produces the following warning on the vehicle on every engine start, and requiring clicking OK to dismiss:
"Charging System Service Soon"
Reverting BdyCM 726-48-02 to the original values prevents the warning from being displayed. Maybe the warning would've been harmless, but it might've annoyed the primary driver. :)
At least two other folks out there have encountered the same warning on 2019 Expeditions:
https://www.expeditionforum.com/threads/door-automatic-unlocking.38785/page-4
https://forscan.org/forum/viewtopic.php?f=16&t=9320
Of course, if anyone's also encountered this warning screen when disabling ASS, and found a workaround, that would be interested to learn.
Also, I understand that disconnecting the ASS battery sensor wire from the positive battery terminal is another method of easily disabling ASS. I haven't played with that yet to see if it produces warning screens as well. EDIT: It does.
Thanks,
Dan
If you can't get FORScan to cooperate for disabling the ASS, you may want to consider the Auto Stop Eliminator: https://www.autostopeliminator.com/store/c4/auto-stop-start-disable-ford-expedition-2018-2019.html
Bulockay
Hampton Roads, Va.
Has anyone located the codes to allow a newly installed trailer brake controller to function? Checked Superduty, F150, etc. forums and those codes didn't work. I have an '18 Limited(no trailer tow package).
Maybe someone with an '18 Expy with the tow package including the trailer brake controller could post what they have for the 2 codes required? Would this work I wonder?
Bulockay
Hampton Roads, Va.
Sorry, the two code addresses are 720-04-01(activate gain control) and 720-07-01(activate trailer brake controller)
APCO_P25
Switzerland
Here are the Codes of my '18 Expi Platinum with TBC and Tow package
720-04-01 E003 0102 0012
720-07-01 8419 8EA0 0903
I hope it works
APCO_P25
Switzerland
mikeyanxu
Oregon
Hello,
2019 Expy XLT.
I was trying to disable the auto start stop feature by following the forescan google doc sheet.
As instructed, under BCM 726-48-02, I changed it to x0xx xxxx xxxx. The second digit is the only thing that I changed.
I noticed that when writing, it says it is not correct and ask to double check if it is a typo. After I clicked yes, it will automatically change the last two digits from xx77 to xx78 then write the change to the module.
After power cycle, start the engine, an error message shows "service charging system soon". So I resumed the factory setting and confirmed that it indeed changed the xx77 to xx78 by itself.
Please help. What does the last two digits mean?
Apparently only changing the second digit from 1 to 0 does not work on 2019 Expy XLT.
I also did the DRL modification. I did the FOG light for DRL plus the parking lights. I did all this work last night so couldn't verify the change. It would just automatically turn on the headlight low beam since it was dark outside. I thought I can trick the vehicle by shinning a flashlight at the light senor on the dash. Man, how silly I was. LOL. Anyways, started the truck up this morning and the mod works.
How does the vehicle know when to turn on headlights?
Mothnuts
Kansas
Hello,
2019 Expy XLT.
The auto start stop disable doesn’t work on ‘19’s yet. I tried and got the same message you did. It works on ‘18’s, but not ‘19’s. Works on ‘19 F150’s as well.
Bulockay
Hampton Roads, Va.
I hope it works
You are a Saint sir, but I’m afraid I gave up and just had the dealership do the dirty deed for me as I had run out of time and had to use the trailer. Thank you so much for the response though!
spc19498
Idaho
Anyone know of a way to write to the IPC yet? I installed an oem brake controller and I’ve tried to write the values from the f150 and Expedition to the IPC but each time it says “the service was interrupted” and changed the values back to stock. Trying to avoid a trip to the dealership. 2018 Expedition Limited Max
TheDoug
Mansfield, TX
Just got around to messing with the software and I got most things to work however...
The data entry while in motion tells me I need to check for a typo. (I used the numbers at the beginning of this thread)
Also auto start stop disable says IPC needs to be modified as well butmi did not see that in FORscan
Anyone have these issues? I am using the latest beta ending in .24
BoinLV
Las Vegas, NV
ROOKIE QUESTION:
I am assuming "BCM" is a different module than "BdyCM as built" Correct? Seems like any module I access that doesn't state "as built" gives language yes/no options, rather than addresses and values. So, if a mod indicates BCM module, with values and addresses, should I use BdyCM as built? Sorry if this is lame...
Bo
TheDoug
Mansfield, TX
ROOKIE QUESTION:
Bo
I am new at this too... but the ones that have yes/no are ones FORscan has made easier for you instead of changing the hex values manually.
In my post just before yours, all mine were done with the yes/no toggle.
jgudnason
Calgary, Ab, Canada
I just checked forscan and looks like there was an update last week and maybe we finally have ability to write to the IPC.
haven't downloaded and tried yet, anyone else?
2.3.24 beta, 2019-08-05 (download)
+ Vehicle database update
+ Some BdyCM module configuration parameters for:
  • Edge 2015-2019 model years
  • Expedition 2018-2019 model years
  • Lincoln Navigator 2018-2019 model years
  • Ka/Figo 2018 model year
  • + Some IPC module configuration parameters for:
  • Explorer 2020 model year
  • Kuga/Escape 2017+ model years
Page W Sutton
Memphis, Tn
I also got the typo error when trying to program the data entry whilst moving option. There is a audio/audio video option for data entry in that module that can be accessed via the menu vs hex code perhaps that is it
Breaker
Katy, Texas
So no codes as of yet for the 2019 Expys, correct? I really want to change out my front turn signals to LED switchbacks, but don't want to wire in the resistors.
tmorris
US
I understand Ver. 2.3.25 Beta is being tested and is finally allowing writes to IPC on the 2019's. Good news if true. Hopefully will be available soon!
Breaker
Katy, Texas
That would be awesome! There are a few things I want to turn off. I also have another obstacle, it's my wife's Expy that I'm doing stuff to. LOL She wants me to leave it alone, but I'm like no, we can make it so much better!
taaangy234
US
Can you share your codes for the DRL modification?
I tried set mine to 2 or 3 made the car throw bunch of errors.
Lights - DRL options BCM 726-11-01 x?xx xxxx xx Change ? To: 0-DRL Disable, 1-DRL 50% Low Beam, 2-DRL Fog Lights, 3-DRL Turn Signal
