4th Gen Expy FORScan Modifications
benyl
Calgary
Has anyone tried connecting with a ‘19 Expedition? I get a message saying “Unable to identify the vehicle”. I’m using version 2.3.18 beta.
send your dump file to the for scan team.
scottdm
Western PA
I checked my DTC's for the first time today after reviewing this thread, and a DTC for the Image Processing Module (IPMB) shows up. I suspect its related to the 360 camera on my 2018 Limited 302A, but the 360 camera seems to function normally. Has anyone else seen this DTC and should I clear it? I have not modified anything in this module via Forscan, so not sure what the issue is or if I should be concerned.
Code: C1001 - Vision System Camera
Additional Fault Symptom:
- Component Or System Operation Obstructed Or Blocked
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Image Processing Module A
scottdm
Western PA
Just bumping this post to see if anyone has any perspective on the C1001 - Vision System Camera DTC in FORScan.
Dscustoms
Utah
Finally! Got a new adapter that actually connected to the other modules and I was able to turn off the double honk. Tragedy is over.
rhk118
New England
Need help with 2 things if its possible:
1. Anyone know how to code off the lane assist warning? Thought there was a way through menus to turn it off but alas there is not. Sick of my steering wheel vibrating....feel like its going to give me carpal tunnel!
2. Way to code the car so I can go to a memory setting for the seat while in drive and not in park? I always to forget to change the seat from the wife setting 'till I'm under way then need to stop and go into park to get my memory setting set...
I've coded off auto start/stop, and added the seat controls to the Sync3 screen....but seems that these would be code-able things?
benyl
Calgary
Just press this button...
It stays off even with an ignition cycle.
rhk118
New England
ARRRRRGGGHHHHH.....I'm such a dolt. I don't even think of those buttons anymore now that I programmed engine auto start/stop off...no reason for my finger to go up there! Can't even blame drinking beer/surfing forums on that one...Thanks so much!
I love this thing tho...
benyl
Calgary
The traction control button on mine will wear out based on how much I press it.
jaketime81
I have a 2018 Expedition Platinum Max with B&O sound system, and I tried to eliminate the ANC/Fake Engine Noise with my forscan,
Code 727-01-01 changed xxxx-x2xx-xxxx to xxxx-x0xx-xxxx and still have Fake Niose? I have done this with other F-150 and Raptors equipt with sony and never had an issue, Any Ideas?
jaketime81
Update, I found the fix: 2018+ found a dsp module, code 783-01-01 and changed ****-xxxx to Cxxx-xxxx.
-Jake
TexasDan
Just want to confirm this method does work. I have a 2018 Limited that I just programmed to do this on. Neither of my mirrors tilted at all when I tried the first time. I did notice my passenger side mirror flicker or click like it wanted to move but it never tilted down. My first attempt was on the driver side and it didn't work at all. It just saved the setting in the down position and never went back. I went to try the passenger side with the same instructions from above and it worked. Then when I clicked back to the drivers side, it worked as well.
A little odd but it did finally work. Only thing I hate is that you have to hit the button to get it to lower. It doesn't automatically do it when you put the car in reverse. I'm wondering if there is an override for this in FORSCAN so it will automatically tilt when in reverse without hitting the button?
Hi. I'm curious which Limited package you have the above experience with regarding reverse tilt side mirrors? And did you find a way to make it automatically tilt in reverse?
Also curious if anyone's found reverse tilt to work (or that it can be made to work) with the 18/19 XLT 202A power side mirrors.
Thanks!
Dan
benyl
Calgary
-Jake
I’ll try this. I tried the other and noticed no difference. Does it also shutdown the active noise cancelling?
Cris
Seattle
Has anyone been able to figure out how to disable the chime when you first start the car? The codes on the spreadsheet cannot be applied on the 2018 platform.
dzchey21
Cheyenne
byz250f
SE MI
Has anyone put the engine temps (actual number) above the sweeping gauges yet?
fetasigma
Madisonville
Got my cable from Amazon and my extended license from FORScan and as a complete novice was able to:
Disable Auto Start/Stop
Disable double horn honk when I step out vehicle with FOB
Disabled fake engine noise,
(I want to hear the real engine noises and get used to it so
when something isn’t right I can hear it right
away)
Panic Alarm now requires two pushes of the panic button, (Kept going off in my pocket)
All of these functions should be programmable from the driver’s menu IMHO but FORScan did the job for me.
What are the locations for the fake engine noise and what are the settings?
Sent from my SM-G892A using Tapatalk
TexasDan
FYI, I tried disabling ASS (auto start/stop) on a 2019 Expedition Ltd Max that was manufactured just a few weeks ago, and found that doing so produces the following warning on the vehicle on every engine start, and requiring clicking OK to dismiss:
"Charging System Service Soon"
Reverting BdyCM 726-48-02 to the original values prevents the warning from being displayed. Maybe the warning would've been harmless, but it might've annoyed the primary driver. :)
At least two other folks out there have encountered the same warning on 2019 Expeditions:
https://www.expeditionforum.com/threads/door-automatic-unlocking.38785/page-4
https://forscan.org/forum/viewtopic.php?f=16&t=9320
Of course, if anyone's also encountered this warning screen when disabling ASS, and found a workaround, that would be interested to learn.
Also, I understand that disconnecting the ASS battery sensor wire from the positive battery terminal is another method of easily disabling ASS. I haven't played with that yet to see if it produces warning screens as well. EDIT: It does.
Thanks,
Dan
Bulockay
Hampton Roads, Va.
Has anyone located the codes to allow a newly installed trailer brake controller to function? Checked Superduty, F150, etc. forums and those codes didn't work. I have an '18 Limited(no trailer tow package).
No members online now.
rockinghranch
