KMcL
I most likely already know what the answer to this is, but I've got to verify...
I've been chasing various codes all pointing to coil packs and plugs for a bit. I finally decided to just swap them all and go from there. In the process of all of this, I come to the coil pack on the #1 cyl... I only see one wire going into the coil pack. I can see what looks like copper wire inside the connector. I cut the wrap around the wire to see if there's a second wire inside to find none at all... I cut down to where it branches off the main wrap of wires with nothing found. It seems like there's no way this should be correct, but stranger things have come up with this engine. So, my question is should there be a second wire going to the #1 coil pack? Also, if there is supposed to be one and I can't find one anywhere, what do I need for replacement? Entire wiring harness???
Thanks for any help!!!
