Adaptive cruise control
Amacron
Louisville Ky
this may be a stupid question. It here goes it.
When the adaptive cruise control applies the brakes. Does the brake light also come on? I’m assuming it does but I’m always in the car and can’t see if it does.
Deadman
Wisconsin
If it doesn't, I would sure think thats a serious motor vehicle law broken!
lobsenza
It does. If the car applies the brakes, the brake lights come on.
jwas1
Newport News
I thought most of the slow down with adaptive cruise control was done by engine braking. If so, brake lights will not come on.
Regan DeMello
Washington
That is what I have read, transmission slow downs no brake light
Deadman
Wisconsin
The Adaptive on my 2014 will dynamite the brakes and send you into the steering wheel if a car turns in front of you. I can't imagine this wouldn't. I shut all that off on mine.
mquick5
Buckeye Country
Geesh, I don't believe my 17 has adaptive cruise control. What model is your 14?
MostlyHarmless
Maryland
Everyone above is correct - the Cruise will start by trying to use engine braking and dropping a few gears to achieve the necessary speed reduction, in which case there is no brake light. If the retardation required is more than that then the brakes will activate and the brake lights will always come on when the brakes are needed.
What's harder to identify from behind the wheel is which is which - a 2 gear downshift and lift off the throttle can feel like light braking, so it's hard in practice to know which is which
Mark
Sgt Darkness
East Tennessee
The only time the brakes activate is if you get within a certain distance from the car in front of you. If you don’t have ACC on and you get within a certain distance (depending on your setting) the brakes will apply hard and your heads up display will activate.
cmiles97
Tampa, FL
No different than not using adaptive cruise control and letting off the gas pedal to slow down.
At some point the driver behind you has to actually pay attention to their driving.
Deadman
Wisconsin
The brakes are on often on our Adaptive in our Flex's. Get a little close to any car and bang the brakes are on, follow too close, brakes.....
Sgt Darkness
East Tennessee
Good explanation DeadHead...er I mean Deadman. Grateful Dead still in my head, sorry. Your mind and feet are still operating at 98 percent, while mine are probably at 80 percent. I have no choice but to leave mine on....and it has saved my *ss on two occasions. You don’t have to worry when you reach my age because you will be sitting facing backards and the cars will be hovering eight feet above the....whatever the roads will be called by then....if you go to Milwaukee look up my bud. His business addy is hotrodbuilders.com. His address will be on the website, tell him Bud from TN sent you and he’ll give you a tour of his business...
shane_th_ee
Seattle
When the active cruise control is engaged, the truck will apply the brakes as needed and the brake lights will illuminate. I know this because I, too was curious. Then I figured out I can see my brake lights reflecting off the diamond plating on the front of my trailer. The trailer brake controller will also apply the trailer brakes in proportion to the amount of braking force being applied to the vehicle. You can observe on the towing information screen.
Regardless of whether or not the adaptive cruise control is active, the emergency brake assist will do the flashy red light on the dashboard thing and slam on the brakes for you if the truck thinks a forward collision is imminent.
scottdm
Western PA
I was using Adaptive Cruise on the interstate during a traffic jam and it's nice for slow speed crawling. When it brought the vehicle to a complete stop, it asks you to push resume when traffic starts moving again. As I was waiting at a complete stop it kinda crept forward like it didn't keep enough pressure on the brake. However, after maybe a minute of being stopped, it deactivated cruise completely and turned on the parking brake.
Deadman
Wisconsin
Hence the nickname I gave my expedition and all newer vehicles, "Electronic nightmare"!
Deadman
Wisconsin
Just for another crazy quirk, Yesterday I was reading up on the fact that if you open the doors, the "Fake engine noises" shuts off, so I popped the door open a jar at about 5 mph and was ready to step on the gas and listen, but instead the F'd up computer threw it into park while it was still going 5 mph and basically tried to shear the "pin" off inside the transmission as it clicked and stripped to a stop. I funny understand that the door open at speed is bad, but I don't need it to tear up my transmission trying to babysit me, soooo stupid.
BTW when the engine sounds are OFF, it is SOOOO much quieter. I'm going to delete this stupid roar that they pump thru the speakers.
Regan DeMello
Washington
Acc has saved my butt. I like that it also pre-charges the brake system to give quicker reaction times
