Adaptive cruise control
Amacron
Louisville Ky
this may be a stupid question. It here goes it.
When the adaptive cruise control applies the brakes. Does the brake light also come on? I’m assuming it does but I’m always in the car and can’t see if it does.
Deadman
Wisconsin
If it doesn't, I would sure think thats a serious motor vehicle law broken!
lobsenza
It does. If the car applies the brakes, the brake lights come on.
jwas1
Newport News
I thought most of the slow down with adaptive cruise control was done by engine braking. If so, brake lights will not come on.
Regan DeMello
Washington
That is what I have read, transmission slow downs no brake light
Deadman
Wisconsin
The Adaptive on my 2014 will dynamite the brakes and send you into the steering wheel if a car turns in front of you. I can't imagine this wouldn't. I shut all that off on mine.
mquick5
Buckeye Country
Geesh, I don't believe my 17 has adaptive cruise control. What model is your 14?
MostlyHarmless
Maryland
Everyone above is correct - the Cruise will start by trying to use engine braking and dropping a few gears to achieve the necessary speed reduction, in which case there is no brake light. If the retardation required is more than that then the brakes will activate and the brake lights will always come on when the brakes are needed.
What's harder to identify from behind the wheel is which is which - a 2 gear downshift and lift off the throttle can feel like light braking, so it's hard in practice to know which is which
Mark
