Well its been just over a week since I first started pulling the motor and the new motor is almost ready to drop in minus all the trimmings. Its been quite an adventure. More like P.I.A.... reminds me what I disliked about working on my mustang. Nothing goes as planned.
Went to install timing cover.... bolt holes in tfs heads wrong size for 5.4 setup.
Sooo... Drilled and tapped got cover on. Went to install canton windage tray. Doesnt even come close to fitting with stock pick up tube.
Cant even modify it to make it fit so its going back. Had to cut oil pick up tube pedestal down to get proper clearance from oil pan.... Glad I checked this because the ARP main stud nuts are larger than stock bolt heads.
Went to bolt BBK headers on and refuse to use paper style gaskets they came with. So I get the felpro metal gaskets (same as stock) and of course they do not fit with the larger exhaust ports of the tfs heads.
So I modify them to work. Get the passenger side header on and go to install the drivers side header and it does not fit!!
Well...... After some modifications with a hammer and die grinder
.... perfect fit.
I did leave out all the things that have worked. Just venting some of my fustrations of today...lol. This just reminded me of what I already knew. When you venture from stock.... there is no such thing as a bolt-on.
I just hope when I am all done it will have been worth it!!
