Anybody Run Different PSI than on the Door?
Expedition Dave
A Tiny Little Dot in Florida
I am running same tire load rating Nittos--albeit 34s compared to the factory 32s.
And lately--just lately--I have kept the front 1 psi higher than the rears. Not even sure why lol I guess it is cuz the front tires run a little flatter (lower) than the rears all the time due to engine weight. I do not think this is a problem for the AWD system if activated.
Now, if the rears are loaded, I tend to add some more PSI to the rears to help handle the weight.
I had one tire guru on another forum lose his mind over that but this was on full-time 4wd (AWD) Toyotas.
I just wondered if anyone else here did anything different?
keny01998
Arkansas
I have 20 inches tire on my 2019 XLT 4WD and I run 38 psi cold. When I put 40 psi cold and the truck bounced a lot especially in the rear end.
DWs-TTEB
Evans, GA
Running 40PSI (all 4) cold on E rated, LT285/65R18x9 General Grabber ATX tires
Fozzy
Riverton
40 PSI for a smoother ride. 45 PSI towing. In my Nitto’s G2’s. I always keep all 4 the same.
Grey ghost
Melbourne fl
Ford recommends the lower pressure for a smoother ride for crybabies. They also wear out quicker.
A couple extra pounds won't hurt
FlyBry
Dallas, TX
41 front, to reduce the feathering on the outside edge, 39 rear
ROBERT BONNER
Denver, NC
I'm sure different tire/vehicle combinations may be different; but, I pyro check my tires to get a feel for how new vehicle tire combinations perform. I benchmark empty vehicle performance with tire pressures set cold at placard recommendations front and rear. Generally, the front and rear tires' temperatures will rise the same amount at any given ambient during normal operation. Then I check heavily loaded. I gradually over inflate rears relative to placard when heavily loading the vehicle and attempt to achieve the same temperature rise in the rear as the front.
What I've learned over time is that if you inflate the rears of a loaded vehicle to mimic the "radial bulge" of the front tires you will end up managing the the temperature increase pretty well, with the caveat that you don't increase the cold pressure above the amount listed on the tire sidewall. Handling/performance/wear seems to be comparable front to rear when I do this.
For my '20 Max FX4 with 18" tires this ends up raising the rears between 38 psi and 41 psi cold when loaded depending on how much load/tongue weight I have.
FlyBry
Dallas, TX
Nice. Where do you take your temps from? Outside, Center, Inside, or all 3? My Longacre Pyro stores all 3, for each tire, but we only use that on the racecars to check our setup when we visit a track we dont have any history with. Which has been very limited during Covid.
