Bilstein 5100 Lift Install
Uturn
That's the code for haven't driven it far enough yet to determine ride quality, and it may be a while since it is the wife's. I also used the stock ride height for the same reason. I had considered raising the front a 1/2" and may do so eventually. At least they will be easy to remove now since Bilstein uses bolts on the lower mounts. I wasn't planning on doing this until last Sunday when I notice the oil drip by the left rear wheel. The other rear was just starting to leak also. The only choices were stock Motorcraft, KYB(rear only), and Bilstein. I have had Bilsteins's on my F350 for 13 years and they were a definite improvement.
Matt Garrett
Nashville TN
I've got the Expy Bilstein 5100s current set at stock ride height. The fronts can be adjusted in 0.8" increments. The backs can be adjusted in 0.4" increments.
I am about to get very slightly larger tires (285/55/20 vs stock 275/55/20) and while doing tires I am thinking about adjusting the ride height.
With that, has anyone only lifted the front by 0.8" and left the back stock?
Or, has anyone lifted the front 0.8" and lifted rear by 0.4"? The later seems like it could give a nice stance and still leave a bit of rake.
Thoughts?
Sent from my SM-G965U using Tapatalk
95cobby
95cobby
Bowling Green, OH
Question for you. It's been over a year since you did this install, any issues with the stock UCAs? I was holding off doing this thinking I needed new Upper Control Arms, but it doesn't look like you replaced them.
Still rides great! Just rotated the tires and checked everything underneath, all looks well. The front is firm still and I contemplated swapping in the f150 2wd version of the 5100s but haven't done it yet. Will likely just leave it alone though.
For those asking, this truck has Method NVs 20x9 and Nitto Terra Grappler G2 295/60/20.
Matt Garrett
Nashville TN
Thoughts?
Anyone?
pm89spur
San Antonio Tx
Does anyone know if you have to do the CCD extensions doing this Bilstein lift on a 4th gen? I haven’t seen or read anything about it so was just curious, I know they were doing it on the ReadyLift kit.
JimW
Lake Gaston, NC
Thanks for this great tread 95cobby. I almost made the mistake of ordering the Ready Lift. I have ordered the 5100's 4wd F150 for the front the the Expeditions for the rear.
I know I'm going to have to move my power running boards back a little.
Does anyone remove the lower air spoiler before the bumper? It sits so low...I would be plowing snow with it.
John McKenzie
San Antonio, TX
I have a 2015 Expedition that I used to have a 3/2 ready lift on...truck looked great and sat level, however, my front suspension was "bottoming out" on small drop offs/bumps...I also blew a rear shock...so, I went with Bilstein 5100's and set front as high as they will go and rear as low as they will go...but now I have a crazy amount of forward rake...I would say the rear is 2.5-3" higher than the front...what am I doing wrong?...it seems like some on here have gotten good results with this setup, but I'd kill just to have mine back to factory...not liking the 5100's AT ALL...the ride is ok, but the rake is so bad I'm embarrassed to drive it...any ideas or suggestions?...thanks.
rx7gslse
Fort Worth
if you replace the CCD with the 5100s the CCD system isn't going to work anymore anyway, as the 5100s are new shocks. adjusters aren't going to help. I'd say teh 5100s are a no-go for CCD folks unless there's a way to program it all out, but haven't heard of that yet..
rx7gslse
Fort Worth
Pictures? Sounds like something is obviously not correct... Did you forget to take the readylift spacer out? Did you get the wrong part number shock delivered?
I know the 2015s have some differences from the 2018+ that this forum is discussing as well...
pm89spur
San Antonio Tx
Thanks for the response. I have a 2019 XLT 4x4, and just found out that the XLT isn’t equipped with CCD, so I think I’m good to go with the 5100’s. I need to crawl under there to verify but haven’t got around to it.
Lou Hamilton
Maryland
As far as I know, CCD suspension is not available on the XLT models. Limited and above only. Also, you get 22" wheels when equipped.
TBaganATX
Buda
Anybody have a squeak in the coils after installing these? I swear I get a squeak out of all for corners, depending on turn, road slope etc. It’s driving me absolutely crazy.
TBaganATX
Buda
Would someone be so kind to give me the measurements of the front and rear wheel well to the ground with the Bilstein 5100 lift.. my crap is jacked and need to fix it. Thank you guys
5280tunage
colorado
looks sweet!
Oh those spring compressors. I've seen one disintegrate before, it's a scary site! Nice work, looks really good.
