Can I safely tow this TT?
Ryan80
Eugene, Or
I have a 2019 Limited w/o the max tow package. This would be paired with the equalizer weight distribution hitch.
SONIC SN211VDB​
UVW (Unloaded Vehicle Weight)*4,620
Dry Hitch Weight*580
Dry Axle Weight*4,040
CCC (Cargo Carrying Capacity)1,270
Interior Height82"
Exterior Height (with A/C)10' 4"
Exterior Width90"
Exterior Length**27'
JasonH
Houston, TX
You would be at the 6,000lb limit, but would likely be ok, provided you're not towing in mountains or anything severe like that. The maximum tow rating drops as elevation increases, so if you're towing at altitude you would lose capacity as elevation increases.
R
Ryan80
Eugene, Or
Thank you. That's what I expected. I am on the fence about getting a different rig to tow with. We have an explorer as well, may keep that as the family hauler and get something that can tow 10k. Thanks for the input.
Fastcar
Army
FL
Where you are weight wise I'd be more concerned about stopping it.
JasonH
Houston, TX
The only half ton SUV rated to tow more is the new Wagoneer. But I think it has a shorter wheelbase, so it may not be as stable. You don't really want to tow a camper that heavy with a half ton SUV. That's 3/4 ton territory.
Scott Hunter
Ontario, CA
You would be ok if you had the max tow pkg. I tow an 8500# (loaded and ready to go) with a 2019 XLT with the max tow pkg, plus Equalizer WDH and we do just fine, even on hills.
Fastcar
Army
FL
No pax in trailer while towing !!
No sh**. I guess I wasn't clear enough. 5 200 pound passengers in the Ex. Gear and food and whatever else in the trailer. In any event he is over or pretty much on limits for the combined weight.
But I always like to be able to stop as fast as I go. ymmv
JasonH
Houston, TX
Have you weighed the whole deal fully loaded? With all the passengers and gear and stuff in the trailer. Could be telling.
Not my camper, but campers this size are required to have their own brakes.
