Exhaust manifold leak
knute
wisconsin
I have an exhaust manifold leak, any advice on fixing this that will make it easier than I've been hearing ? Should I replace with an aftermarket manifold ?
mic_1011
yonkers n.y.
i've been having the same problem with my 98. took it to a mechanic and it was ok for a few months. now it's back again
02Expedition
central mass
my 02 has the leak too..I have been thinking maybe now is the time to put on the shorties...I am thinking Gibson Headers....
jeff1998
Highland, IL USA
I have the same trouble with my 98 5.4L. The manifold warps when cold breaking off the stud and nut holding it to the block. When it warms up it almost goes away. Any good fix for this??
tonydiv
technical advisor
Middle River, MD
I've been thinking about headers too. But those super wimpy studs have me concerned. They're tiny and I'm worried that they will break off if I try to remove the nuts. Anyone know how big of a job it is to replace the studs?
Never_Evil
Green Bay
I am planning on doing this job in the near future. Not only did some studs break off the engine, but the studs that hold the manifold to the y-pipe deteriorated. With the truck up in the air and supported. There is enough room to remove the wheel and have access through the wheel well. You can rent stud removers from Autozone, but you would definitely need new studs. If any of them break off, you will need to get a drill and a stud extractor( start small and work your way up). Worst case scenario is that the stud is not coming out for any reason, you will have to over drill it and insert a helicoil or retap it. Not a fun project due to limit space.
aircargoo
new jersey
i would replace both sides with better model then stock....period.
job like that is $200 a side maybe.....and yes...better shop for the ones with bigger bolts and threads...
...u gotta get the replacements as well.....not cheap job w/warrenty.
i c these motors worked on alot(serviced)...they CAN go over 350,000 miles with SERVICE THOU......4.6 ive seen with 290,000 the most.....
these trucks are used in construction co. there freaking abused fairly well day in day out...dogged....lol
KevyKev
Florida
air cargo,
You speak the truth my man......I'm pushing 370, all I need right now is a intake gasket. I had the same problem, and the mechanic redrilled new holes and stronger bolts........
gijohn45
layton, utah
I bought new studs and bolts for $6.75 each from the stealership... it takes 8 per side... a local muffler shop charges $200 to fix the problem... its usually the back two that break...
nvycrmn
Springville, IA
gijohn, i dont think ive seen pics of ur rig. got any posted in here somewhere? im running the same setup minus the gears.
97EB5.4
NC
I just got done doing this to my 97 5.4L. Got the summit version shorties which is the pacesetter essentially. Took the fender liner out and got the old manifolds out. I did not have enough room to remove the studs by drilling them out. The stud removers sold through advance and autozone are the same. made by irwin i believe. its a good set. however the studs on mine were rusted and the diameter of the stud had shrunk and the remover set did not go small enough to remove them. So instead of breaking off studs in the heads to make me more pissed off i jerryrigged it. Didnt want to do it this way but I was very short in time and didnt have the funds to remove heads and all that. SO i got the muffler putty used to patch holes and put it on the header side and on the head side making sure to get it around the studs which were only the bottom of the rear cylinder and the top of the second cylinder. So I have not had any leaks. THe stock h pipe or y pipe whatever it is bolted up to the header flange just fine with no leaks. I also got a good deal on the dynomax catback from summit too. Just did not have the time to install. So there it is in a nutshell. Took me a weekend. Passenger side is easier than drivers side due to driver side having the brake line manifold setup right in front of the first couple of cylinders. I didnt take pictures though. Kinda wish i had. But as long as you take out the liners which is a 5.5 mm i believe and there are about 6 of those bolts one of which is on the bottom rear corner of the fenderwell up underneath. So make sure to look for that or you will be fussing with yourself. Any questions? Have fun.
