ForScan Tweaks - 2015+
chuck s
I remember buying blank keys for both my '02 Explorer and '07 Expedition and having them cut at the hardware store. I was told "They won't work.", but I cloned them within minutes using my existing keys. This still work with the '17 trucks? Not sure why I think I need a 3d key anymore though.
-- Chuck
flexitis
US
On most if not all Ford's if you have 2 keys than you can program a 3rd yourself.
If its push button start than there is a backup slot (on my Flex its in the center console) where you put the key when the key battery is dead or when programming a My Key or to program any additional key.
On the Integrated keyhead I'm not sure how to program it but I'm sure it's in the owners manual.
Sent from my LG-LS993 using Tapatalk
Muddy Bean
One quick request. Here in Michigan this winter has been brutal. Very very cold for weeks. As in below zero or single digits. My max 15 minute run time for my remote start isn’t always enough to warm the cabin. Is there a ForScan way to extend that time interval to say 20 or 25 minutes? Anyone ever poked around for this?
flexitis
US
When you remote start the vehicle after it starts do the remote start procedure again and it'll extend the run time to twice as long.
LokiWolf
LokiWolf
Moderator
Richmond VA
15 is the maximum per cycle, 2 cycles before the truck must be started for real.
HockeyPuck99
Frisco, TX
I am new to this group and have been looking into Forscan to see what I can do with my 2017 Expedition. I have started to read this whole thread but it will take me some time to go through 41 pages :).
Is there a spreadsheet or something similar for a 2017 Expedition. I found the one for the 2015, which I assume would get me most of the information for the 2017. Is that a correct assumption?
ExpeditionAndy
Fort Wayne, Indiana
Welcome to the Forum. There is a google spreadsheet. Here is a PDF of it. These are the ones that work on the 2017 Expedition. It may have been updated since December so you will have to search the pages to find the links.
  • FORScan 2015 Expedition updated 12-1-17.pdf
HockeyPuck99
Frisco, TX
Awesome! Thank you sir!
I'm doing some learning right now so I'll keep reading through the thread but I'm excited to try some of this stuff out.
Muddy Bean
I know this isn’t quite on track, but my dad has a 2015 fusion and he merely wants his lane change signals to be set to the full seven blinks...I did this on my Expedition without issue. Anyone know off the top of their heads the code line to change for the ‘15 fusion? If not I’ll drag my bum over to the ForScan forum and sift through it to find the line....
East-TN
Air Force
TN
Mustang and Expy share the same location, so suspect the Fusion will also...try:
SCCM 724-01-01 xxxx x?xx xx
Lane Change Turn Signal Flash:
Change ? to: 0-3 1 Flash, 4-5 2 Flashes, 6-7 3 Flashes, 8-9 4 Flashes, A-B 5 Flashes, C-D 6 Flashes, E-F 7 Flashes
Carl H
Rapid City, SD
Alright guys, I screwed something up in the wife's truck and she's mad about it. I was trying to turn the voice nav on (SYNC 3), and it didn't work. So when I changed the line back to the original digit, she is unable to hang up the phone when using CarPlay with the steering wheel controls.
Fortunately, the truck is in the body shop getting the damage repaired and I have plenty of time to figure out a fix. Anybody have an idea of what could have gone wrong? I have not updated to the latest firmware if you need to know. Also, I was unable to reload the As Built because something went wonky somewhere.
East-TN
Air Force
TN
To clarify...you were trying to activate/enable the turn-by-turn directions voice guidance on the Sync 3?
HockeyPuck99
Frisco, TX
Does anyone know if it is possible to add time to the auto running boards going back up when the doors are closed? For my 2017 Expedition EL Limited, I believe the default is 2 seconds after you shut the door the running boards go back up. I am curious if I can make that delay longer.
I'll start searching the F150 forums but I figured I would see if anyone else with an Expedition has already done some research.
flexitis
US
When CarPlay is running it goes through USB not Bluetooth so the steering wheel controls will not work.
flexitis
US
Also if by adding nav prompts you meant adding nav to SYNC 3 that came without it your only option is to buy a nav APIM.
The hack to add nav to SYNC was only on SYNC 2 (my ford touch).
ExpeditionAndy
Fort Wayne, Indiana
That is a good question. Wouldn't mind finding that out as well. Often I close the driver's door and by the time I open the passenger door the running board is on the way up and then it reverses and goes back down. So I would mind adding 1 or 2 seconds to it.
