Good things ARE coming our way from ICON Vehicle Dynamics, or so they say
LRNAD90
Maryland
EDIT - Okay, Scratch most of this, Just read some other threads that I must have previously missed, sorry for being redundant..
I only asked about rears in regard to the 07 like Adventure Driven’s but the rears are identical across the board for the 07-17s Expedition so it won’t make a difference.
Are they?? Everything I was finding makes it seems like there is a difference in the '15-'17 models rear suspension. Maybe it is minor, I'm not clear, but Bilstein offers replacement shocks up to MY 2014, but not for '15-17 MY, for example. I wrote to Stage 3 Motorsports at one point asking about rear shock options and was told there were 'significant' differences in the rear suspension, and that the shocks from the earlier 3rd generation trucks will not fit?
Q_bubble.jpg I'm assuming from the description that these will not work on the 2015-17 Expeditions, curious why not if so, given the minimal changes, and what other quality shock options are available for the '15-'17 models? Thanks..
A_bubble.jpg The rear suspension and driveline of the 2015-2018 Expeditions actually changed quite a bit to handle the extra output from the 3.5L EcoBoost, which caused issues with shock fitment. Unfortunately, Bilstein does not currently have replacement shock options for the later Expedition Models.
Also doesn't seem to be a Rancho quick-lift available for the '15-'17 unless I missed it. Appears it is only available for '07-'12 MY Expeditions?
No doubt there is a need for a good quality lift option for the expeditions, so hopefully ICON will offer kits for both versions. I was also wondering if there work with Adventure Driven would lead to a kit, but had kind of given up hope to be honest. So thanks for the heads-up..
Stage3s answer is pretty uneducated. The driveline in unchanged from 07-17 Expeditions using the same transmission, transfer case, driveshaft, 9.75” gearset and diff, etc. There are Zero driveline differences. I believe Ford changed the mounting locations on shocks on 2014’ model year trucks. 07-13’ is one suspension style and 14-17’ another. 2018 suspension is totally different than a 2017 as well.
Black
Black
Kentucky
The only difference is that the 2015-2017s have the lower spring perch attached to the shock body.
The original 04-14 models had a removable lower spring perch. If you buy a new Ford unit for 04-14 you get the new unit with the lower spring perch model that is the same part number as the 15-17.
I have been unable to locate older OEM removable spring perches.
So you can take the lower spring perch off your OEM 15-17 unit (yup you have to cut and destroy the shock to do this) or dependent upon how good your local NAPA guy is they can super special order the spring perches for you.
I have pretty much written off Stage3motorsports, I have contacted them on numerous occasions in regard to Expedition suspension inquires and they did not even bother to respond.
If you are interested in the research I and a couple others have done on this topic to date take a look at these threads:
https://www.expeditionforum.com/thr...l-shock-update-things-are-looking-good.36631/
https://www.expeditionforum.com/threads/bilsteins-installed-on-my-17-limited.36886/#post-315003
Zero Offset
That specific combination likely so.
Though there are a bunch of spacer height options available that coupled with the Ranchos will keep you under 3”
Thanks, makes sense. Man, that would be awesome to be able to have a 4"/3.5" lift though but I'm sure that would require a ton of other mods to be safe.
LRNAD90
Maryland
Seeming more and more like Stage 3 doesn't have quite the level of expertise they purport themselves to be..
Thanks to "Black" and all others that have been digging in and finding the answers..
tbone1004
Greenville, SC
now we just need one of them to come out with some sort of air adjustable coilover so we can get load leveling of some variety, even if it's manual....
Adieu
SoCal
Email customer service is usually Rajeev from Mumbai, who also handles a few other firms... which might just be gluten-free hipster ice cream and ladies' knickers made out of organic hemp.... and, chances are, he never even made it to middle school...
Dorzak
California
Reminds me of trailer company I contacted about towing related items. They said the didn’t list Expedition in their pages because they didn’t list any SUVs with less than 3500 lbs towing.
Adieu
SoCal
Lol my sports sedan is rated to tow more than that
Dorzak
California
I replied to them that the Expedition is based on the F-150 for transmission and engine, but different rear axle and provided a link to the Ford towing info. Not naming them because they apologized and said they would look into updating it. I had been engaged in a flight of what if - applied for a job out of state and comparing buying a box trailer to cost of renting a moving vehicle. The cost was similar for a one way move and gave me the use of the trailer after the move. (California - Wyoming)
Grover6
Calgary
Well, for what it is worth, I sent off an email to Icon asking about upgrades for my '16 ,and they said that they were working on a product for it...
Guess we will see. Hope it is sooner than later. Need to get on the build!
Dan G
Reno
Anyone hear an update on availability? I'm debating replacing my shocks with Bilsteins or waiting for this kit to come out...
Black
Black
Kentucky
Not heard anything. I blew a rear shock so had to do something now.
I went with the Bilsteins they are cheap enough for the time being.
16plati
VA
These would work on our 15-17s up front with the two vertical studs that attach to the LCA
Black
Black
Kentucky
Yup any F150 coilover even the ICONs will work but you are stuck with a mismatched rear.
16plati
VA
Not worth the money in my opinion unless all you do is off-road 24-7
joethefordguy
Readylift is nothing more than a strut spacer that you pop on top of the factory strut essentially pushing everything up X”s (based upon the kit purchased) the most popular for the Expedition is 3” front and 2” for the rear. It also tends to provide crap ride quality. The Expedition is an independent suspension front and rear so the ride quality is not degraded too much. Spacers on a live axle are horrendous for ride quality.
This is a completely new coilover assembly completely. Likely will be height adjustable from 0-2.5” (considering that is the F150 models adjustability).
For other models there is a coilover, a coilover with external reservoir, and a coilover with external reservoir and dampening adjustability.
So you gain much more suspension travel without loosing ride quality and not particularly loosing longevity of the other factory suspension parts. In some cases and application ride quality is improved over stock.
Here is a video somewhat explaining the difference.
The coilover is the ride height adjustable type.
Granted in this video the Bilstein 5100 is the strut only and you reuse the rest of your stock components and the ICON will be a completely new unit the principle and engineering behind the two are the same.
I'm confused: " It also tends to provide crap ride quality. The Expedition is an independent suspension front and rear so the ride quality is not degraded too much."
which is it?
Black
Black
Kentucky
which is it?
Depends on if you are an independent suspension or not.
Ride quality is degraded in both the matter of how much is dependent upon the setup.
Independent suspension helps to soften it out.
I’ll say that I now have rear spacers as they are the only option at the moment.
Paired with Bilstein 4600 I am very surprised and impressed on how well they ride compared to other vehicle I have ridden in with spacers.
Gr4ck3L
FL
If the plan was to upgrade suspension (over 3"), and the effort ends up looking at aftermarket f-150 front end suspension, would there be a reason not to convert to a complete OEM Raptor front suspension for corrected geometry (besides cost)? I searched the forums but I didn't really see anything in that lane.
The backend would be a whole other ball of wax.
Adieu
SoCal
Raptors are wider than F150's, so the geometry wouldn't necessarily be exactly the same
Geometry correcting aftermarket F150 parts might work better, all front control arms should fit iirc
And as to the steering and 4wd stuff, I haven't a clue what is or isn't compatible at all
