Helwig stabi.
B
Bmac1955
Southern Cali
Sorry for half assed post. 40k on a 2019 xlt. Placing an order for front and rear sway bars. Would one replace the attachments also. Swaybar bar end links?
B
Bmac1955
Southern Cali
If reusing the stock links, don’t use an impact on them and observe the torque specs.
Edited by moderator: Keep your comment out of the quote box (above marked by line on left) to not have your comment hidden at end of quote. End edit
Thanks for the reply. I do plan on ordering the pair. Planning to have a suspension shop do the install.
B
Bmac1955
Southern Cali
I do have plans on ordering them thru a suspension shop and do the install. Just curious about purchasing the links as well. I just noticed my right front shock leaking and plan to have all 4 replaced at Ford along with an alignment.
TheDoug
Mansfield, TX
Sorry..........Big hands small phone. What can I say.
I have that problem too.
There a big thread here on the links to buy. I forget model numbers of end links but I bought moog for the rear and energy suspension for front (fronts requiee a little trimming see the post for details). If you need help feel free to pm me.
Edit.... search hellwig and you should see it.
B
Bmac1955
Southern Cali
Thanks for the info. I did order front and rear sway bars. Takes 4 to 6 weeks I was told. They said due to making them. I think BS. The company is here in California. So.........
cmurphy2
Dallas
I would use OEM links. I tried Moog and started clicking in less than 5K miles.
5280tunage
colorado
I have had good luck with the energy suspension links but I think even they are knocking at this point. My factory ones didn't fare very well either, I think they are too weak to handle the torque that the hellwig can produce, but that's just my observation, not scientifically measured. I have a new set coming soon that I'm going to try just to see if they are much better.
