hope for help. 2003 navigator
Glenn Sawyer
Aberdeen, wa
i need to know what wires i need to use to get power to the seat from an 03 navigator. just the driver side power seat. not worried about the heat or cooling right now
Hamfisted
Ft Lauderdale
Should be a dark green wire coming off a 30A fuse 109 feeding power to the seat control module (located under the seat...) , and a black ground wire. Then you have a whole spider web harness running from the seat switches to the module and from the module to the seat motors.
The power seat wiring diagram is on page 4537 of the service manual. If you don't have a service manual you can download one here: https://spaces.hightail.com/space/hoVVsN5P2A
G
Glenn Sawyer
Aberdeen, wa
would you happen to have that link for a 1st gen?
Hamfisted
Ft Lauderdale
Do your power mirrors work ? 'Cause there is a known issue with a splice in the wire harness near the fuse box coming apart, killing power to the seats and mirrors.
thegerb50
