Scrolling through this post, and updating my ‘05 mileage: 154,200. Replaced the original brake pads/rotors @141k. I’m on my 4th set of tires, replaced all of the struts @ 98k (one was leaking). It’s still a good ride. I’m looking at small areas of corrosion to sand & prime, and considering a paint job in the near future.‘05 XLT 4WD. I hit 119,000 miles this week. I did the timing chains, cam phasers, vct’s, all roller followers, lash adjusters and a melling hi flow/pressure pump @ 99,000. One of the followers bearings siezed. I replaced the throttle body due to going to run safe intermittently @ 98,000. I put an aftermarket one on that’s starting to fail. Going to drop the bucks on a motorcraft one this time. Overall, it’s been a good ride.
i've just fixed my leaking rear side window. Large gaps develop between the window frame and the body work. i put in flowable silicone sealer meant for windshield repair. this gave a 99% improvement. I followed up with Captain Tolley's leak sealer (yeah, its a thing). 100% fixed!I was hoping to see more posts from '05 owners!
I've got the '05, 2WD, King Ranch. Bought it in 2010 with about 110k on it, now it has 245k. I've replaced radiator support, transmission, front/rear wheel bearings, front/rear suspension components, all coils, a few injectors, cats, O2 sensors and of course the usual things like brakes, alternator and starter. The A/C has been a problem for a while now. Rear blend door (fixed) and compressor has been replaced twice. Once by me, once by the dealer to be sure it was done "right." After the dealer did their work it now randomly pops the pressure vent and blows my coolant out. Can't find a solution to this one yet. Roof window leaks off and on and now the rear side window has developed a leak. Need to fix that this weekend since there is water all over the floor in the back now. Overall a good rig, but definitely not without its issues. I'm beginning to hear the Cam Phaser rattle....
Texas - Over the years, I have tackled the same things you have except I haven't had problems with the radiator support, the transmission, alternator or starter. I fixed my leaking side windows and roof rack mounts with flowable silicone sealer. But will take a look at that Captain Tolley's if I have to re-visit it.i've just fixed my leaking rear side window. Large gaps develop between the window frame and the body work. i put in flowable silicone sealer meant for windshield repair. this gave a 99% improvement. I followed up with Captain Tolley's leak sealer (yeah, its a thing). 100% fixed!
