I don't even care if you laugh, I did, afterwards
Discussion in 'General Discussion' started by coupe11, Nov 26, 2019.
  1. coupe11
    coupe11 Well-Known Member
    62
    45
    18
    Aug 9, 2019
    Pulled the 14 Expedition out of the carport yesterday to take care of a leak that was dripping rainwater on the sunroof area.
    Parked it out front of the house, got some of the spray leak stuff that works (sometimes - I sure wouldn't get in a boat made with it) and sprayed the inside of the roof with it around the seam.
    Came back to the Expedition, put all the wife's Costco shopping trip insulated bags back in the rear of it and decided I'd try to find out why my mother-in-law was complaining about the door locks not work on the passenger side rear door.
    I couldn't find anything wrong with that door. I worked it with and without the keyfob lock button, worked it from the driver's door button (locking/unlocking) and got in the seat and shut the door. Locked it, grabbed the door handle and opened it. Locked with the key fob and then grabbed the lock "button" and pulled it up to unlock the door and opened it.
    I got out, looked at the child proofing lock "button" on the inside of the door and worked with it to make sure it worked. I wear glasses so I had to get at just the right angle (sun was bright, but not shining on the door button there) to see the right position for disabling the door handle inside. Put it there and made sure it all still worked and then moved it to lock and made sure the door handle didn't work - making sure everything worked as intended.
    Then I decided to repeat it on the other side. Heck, I just figured out the passenger side, right? I walked around to the drivers side rear door, opened it up, looked at the child proof button and saw it was in the wrong position. I thought, oh, she said back door but she meant the one on the driver's side. So I put that button in the same position as the one of the passenger side.
    Then I got in (little tight for me with the drivers seat back where I need it to be) and made sure I wasn't scraping the drop leg holster or FNS across the leather seat while getting situated and then I pulled the door shut and hit the key fob lock button. I grabbed the door handle and it wouldn't open. I hit the key fob unlock button and the door unlocked. But it wouldn't open. I did a couple repeats of locking/unlocking but the handle would not open the door.
    Well, only way to get out is to slide my big ass, feet, legs across the seat while getting my feet hung up on the windshield sunscreen I'd rolled up and dropped in the floor before moving the Expedition and my wife's umbrella. All while trying not to drag the FNS and holster (Safarilland 6305 with mag pouch attached) and not twisting my already aching back anymore than I can help. Took some careful "scooching" across the seats to get to the passenger door and get out.
    I go around to the driver's side rear door, grab the handle and it opens right up. I start checking for the method to get the interior door panel off since it's "obvious" something has come loose in the door.
    My wife comes out to get the mail and I start complaining the darn Expedition is already broke. She's standing there looking at the mail while I'm trying to explain why it's not working right. I show her the botton on the passenger door and show her how it works. I take here around to the driver's side to explain the problem and she's paying more attention to the mail than to me and that further aggravated me.
    I get her to look at me and look at the door and show her the switch and she says, "No wonder it doesn't work, you've got it in the wrong position." I looked at her and told her it was in the same spot as the one of the passenger side, I looked at it. She says, "It's in the locked position, look at it." I bend over, shade my eyes from the sun, get them to focus on the little embossed design in the rubber seal and sure enough, it's in the locked position.
    So, now I know Ford uses the same switch for both sides but they are reversed due to the change in position from one side to the other.
    I don't think she was shaking her head as she walked away reading the mail. I didn't look at her to see.
    It ain't every day my wife comes outside to point out what's wrong with a car/truck.
    I told her she taught me something and she told me I should listen to her more often (not about cars/trucks but about other stuff).
    Go ahead. Laugh. I did.
  2. stamp11127
    stamp11127 Super Moderator Staff Member
    62
    6,089
    1,186
    Mar 10, 2012
    Temple, Georgia
    You are now a senior citizen like myself. I crossed the 62 threshold last Sept. Getting old is hell......memory and eye sight are the first to go.
    I have tools in the tool box I didn't know I have & don't remember buying them either
  3. MrSticker
    MrSticker Full Access Members
    1,756
    718
    May 4, 2016
    Penfield, New York
    That's a weird coincidence. I just noticed that on my last trip. I religiously lock the doors EVERY time I get out on a road trip. Since I'm nearsighted I cant go by a "click", I have to confirm by observing the latch down and I even try to pull a rear door handle at times. I was used to the configuration of the driver door, so when I tried to lock the passenger door it would unlock. That's how I figured this out. Small detail but it matters.
    Anyway … my 2003Expy is not like that. They use a different switch on those doors so you always push "outside" to lock. Not so with my 2014EL. That puppy has the same switch on driver & passenger door so you have to look for the icon and press it the right way. Just noticed that!
    I'm sure some automotive Engineer got a bonus for that suggestion. Less parts to stock and track through the supply chain. Higher volumes on that part so cheaper. Screw the consumer
  4. Eddie bauer Owner
    Eddie bauer Owner Member
    46
    Sunday
    Meridian, ID 83642
    Eddie bauer Owner: I have a 1997 w/the child safety switch also! You have to move the switch til it (snug-click's) down! (i found both driver's & passenger door's are the same)! On your 2014: that switch is newer than mine! If it don't stay down: you will have to remove the plastic panel, rubber-plastic shield & test-look at the inside mechanism to see if there's anything binding it! ?If nothing? Check the inside lever for any binding debri!
    U might use a silicone sealant that's made to stick to the sunroof's material; buy the wrong sealant: it'll leak again!
    If you have eye problems: It may be something more than age related; May i suggest [photo-gray-transition-lenses] {in the sun or in the house under Led bulbs: the brighter the light; the faster they turn dark: So there for your prescription clarifies better as they get darker}
  5. Eddie bauer Owner
    46
    Sunday
    Meridian, ID 83642
    Eddie bauer Owner: The child safety lock is an independant switch in the door! You cannot (lock & unlock [that] lock w/either a key or security key fob! (especially when that switch is inside the outer door frame)
  6. rjdelp7
    rjdelp7 2000 XLT
    1,136
    258
    Nov 30, 2014
    NY
    Too long, to bother finish reading.
  7. coupe11
    62
    45
    18
    Aug 9, 2019
    You made me chuckle, not good enough for a laugh. I would say, "Try harder." But you seem to give up easily.
  8. Frank Wilson
    Frank Wilson Full Access Members
    46
    96
    38
    Oct 2, 2016
    PlymouthMA
    Give him a little credit. He at least knew it was "too long" for him.
    JExpedition07 likes this.
  9. rjdelp7
    rjdelp7 2000 XLT
    1,136
    258
    Nov 30, 2014
    NY
    Boring...I having important things to do.This is a help and advice forum, not a long winded story, chat room.
  10. Frank Wilson
    46
    96
    38
    Oct 2, 2016
    PlymouthMA
    FIFY
Share This Page
