I have cam phaser issue :(
StealthyBulldog
Manitoba Canada
@Vipersinu2 not sure why I can't see 90% of your posts all of a sudden. Is this the same for anyone else? I see you quoted Timmytan, but can't see anything that you typed. Wondering if it's because I'm not on the tapatalk app? Dunno, but it's annoying! :)
Vipersinu2
Florida
I was asking how many miles on your truck when the cam phasers and trubo were replaced?
rjdelp7
2000 XLT
NY
Correct me if i'm wrong, but weren't cam phasers one of the most common and potentially catastrophic problems on the previous-gen Expeditions? (I had a '12 Expedition Limited before my current '19 Limited)
If that's the case, did FoMoCo seriously not address this problem at all when they redesigned for the current-gen?
General Motors make a Eco-Tech engine that has similar Cam Phaser and timing chain issues. This design needs religious maintenance. However, The Coyote, has not had a major failure with them. Most of them get run hard in Mustangs. I think Ford knows, people having this issue are maxing out oil changes and using cheapo filters.
Fozzy
Riverton
I think you are right. I don’t know if all Ford dealers do this but mine use to offer 3 oil and filter changes for $79.99. It’s now $99.99 for 3 and it expires in one year. I asked the service manager how they make any money on that deal. He said the usual, bulk pricing, super fast tech’s and customer appreciation. He also said if you own a EcoBoost and want it to run good and last a long time, 5000 miles is the sweet spot. You don’t need catch cans, high dollar oil or any of that crap. Just keep the oil clean and new. I have done this with my last two EB’s and never had a problem with the engine. Knock on the plastic engine cover for luck. Probably jinxed myself.
Dice Roll
Craps Table
The guys on yellow bullet say not to go over 5k miles and to stay under 550hp if you want life out of an eco boost
I have to say that my truck has the updated parts since it’s an August build and it sounds like a hammer factory for first minute or two. It doesn’t sound like the videos I’ve seen posted of phaser failure. It’s a loud engine.
used to be stuff had air pumps that came on during initial start up and I wonder if this engine uses one as well?
Gumby
Beaumont, Alberta
When we had a 2010 Flex (factory ordered) whenever you would open the door the fuel pump or fuel system (IIRC) would pressure up. You could hear a slight whine for about 2-3 seconds. Perfectly normal. I do not hear that with the Expy.
TheDoug
TheDoug
Mansfield, TX
Well I took in in Monday and I heard back today that it is the cam phaser (which is what I told them and took audio/video off issue). There is some part that is back ordered because of all the failures... hopefully this doesn't take too long.
Bill Schell
Montana
2018 with only 48000 miles and I'm getting cam phasers and timing chain replaced next week :mad:. I've had the cold start tickety-tick noise on and off and while on a road trip to ID last week, the engine light came on. This now very long in the tooth issue with stretched timing chains and cam phasers is a really poor reflection on Ford and their Engineering group. Seriously, there is GOBS of internet traffic regarding this issue going back nearly a decade.... WTF!!
While I thankfully purchased the Premium Care extended warranty (Flood ESP), will get a free loaner, and am only out $100, but I hate having this extent of work done a brand new car. If Ford had to reimburse customers for their time to/from and sitting dealerships, they'd be broke - FLAT BROKE. The job takes 3-4 days primarily because the sealant has to dry that long.
I was told by the service specialist that the replacement parts are a new/improved design, though I haven't been able to find anything on that specifically. Does anyone know whether this is fact or fiction and what exactly has been changed?
Artie
Georgia
I hate this for you!! We have similar aged vehicles, mines a 12/23/17 build date with 30k on the clock and I’m always a little scared To hear the rattle on the first start of the day. So far so good and I pray the day doesn’t come.
As for updated parts... I’ve read the same thing on the blue oval forum and a lot of those guys are ford employees so there should be some truth to it.
Best of luck!
Bill Schell
Montana
Best of luck!
Yeah thanks. I too hope you don't experience the issue but being that it's an inherent design flaw, the odds are high all of owners will. I'd love to know the percentage of 3.5L's that have had the issue - no doubt that is highly protected data.
Certainly use and maintenance factor into it, but unless it is also associated with different component manufacturers of those parts (suspect there might be multiple), one would think virtually all engines are at risk? What is really nuts is Ford Engineering not being able to get this design flaw worked out. It's not as if this issue just surfaced.
I'm going to try and contact Ford and get specifics on whether replacement parts are in fact re-designed; be it dimensionally, material & process, or both. I'll pass along anything I find.
Soliyou
OK
This should be covered by the Powertrain warranty, why do you have to use the ESP??
Bill Schell
Montana
Yes, it is. The service specialist mentioned that to me. But regardless, Ford Engineering needs to step up their game.
Soliyou
OK
I totally agree! Even if it is covered, I don’t want to open the Engine guts this early!
by the way, this is supposed to be due to plastic locking pin failure and shouldn’t be related to timing chain stretch as gen 1 ecoboost.
DMW1
Davidson, NC
I was looking at a used Expedition and it seemed fine when the salesman drove it up to the showroom. I went back a week later to look at the car and this time I was there to hear it cold start. It sounded like a bunch of bolts clanging around in a coffee can for a few seconds then was fine. They would need to discount that car by a few thousand before I would consider it.
Bill Schell
Montana
If it is not under the 60000 powertrain warranty I sure wouldn't buy it. I purchased my 2018 used late last summer along with a Flood ESP Premium Care, 8 year/120k, extended plan. My engine occasionally made a slight ticking noise at first start-up and it lasted a few seconds at most. It wasn't until a road trip a couple weeks ago that the engine light came on, then went off, then came on, then went off again.
Everything I've been reading about this "start-up noise" is that it's "normal" - just something cam phasers do. That sounds like a great party line for "we have a piss poor design and no remedy for it". Mechanical noise like this are internal parts wearing on each other - and not in a normal wear manner. Whether that's from poor design or manufacturing tolerances, poor material choice, or insufficient lubrication, I don't know for sure - and thus far I have been unable to find consistent information on a root cause.
The model 3.5 EB (D35 model) came out in 2017. Clearly they missed the target in resolving what has been a 10+ year issue.
https://en.wikipedia.org/wiki/Ford_EcoBoost_engine#3.5_L_(D35;_second_generation)
Bill Schell
Montana
The D35 switched from the Gen 1 single, long chain, to a two chain design. It would stand to reason that would help the "stretched" chain issue... or has it? Perhaps it's still to early (not enough mileage yet) to know whether the number of timing chain and cam phaser faults is less than the pre D35 engine, but early indications are that the design problem has not been corrected.
This is from another forum:
"Ford used a super long single timing chain on the 3.5L Ecoboost. If a 1 meter long chain stretches 1%, then it's stretched 1cm. 1cm is like a full tooth off. If a 1/2 meter chain stretches the same 1%, it is a half tooth off. The auto tensioner for the long chain has to compensate 2X more than a short chain.....
There is a reason the 2.7L Ecoboost has gone to a two chain system. I expect the 3.5L gen 2 Eco will do the same. This isn't an oil problem it is a design problem."
rjdelp7
2000 XLT
NY
The Rolls Royce Merlin V12 aircraft engine, designed in the early 40's uses a shaft drive, not a chain. The problem with Ford timing chains is the tensioner, being run off oil pressure and plastic guides. If the seal fails or engine is low on oil it destroys the guides. The cam phaser noise, being fixed under warranty must be severe or Ford wouldn't fix them. The 'new' 7.3l Godzilla, is not OHC, it's pushrod(aka no phaser or long chains). Has Ford given up on this design? It's possible.
Bill Schell
Montana
Does anyone know if a TSB was ever released 4Q19 as expected? No luck yet getting response back from Ford Customer Service.
My dealership is replacing cam phasers and timing chains. I didn't ask about the VCTs, tensioner, guides, etc.
