leaking water from back of engine.......Is that a bad water pump
whiteghost
Columbus
Water leaking from back of motor......Is it from a bad. Water pump,cause it keeps my resovir empty
stamp11127
Temple, Georgia
Welcome to the site.
The water pump is on the front of the engine, leaks from it will not show up in the back of the engine. Most of the coolant leaks are attributed to leaking heater hoses where they connect to the heater core, a coolant pipe that runs in the valley under the intake manifold and head gaskets.
BerndM
Placentia, So. California
A looonnnggg time ago I had a water leak from the back of an engine and it sadly turned out to be a leaking freeze plug UNDER the bell housing.:flame:
stamp11127
Temple, Georgia
Whiteghost what are you using for coolant? If you are running straight tap water, a rusted out freeze plug is a possibility.
JCool
Kentucky
Does anyone know where the other end of the metal hose goes too? I know one side is back of water pump, but where does it go to after it comes thru the valley, anyone know? Help please!!!
