Like panhandler said you'd know if it blew a plug out because it would just be sitting there not screwed in. I don't think they all blow as spectacularly as his did but you should be able to notice. As far as stripping the cylinder head it's always a possibility with aluminum heads. I recommend blowing out the hole with compressed air then shooting a little PB blaster down there to lubricate it and loosen it up. Don't squirt to much or you'll have to crank the engine with the plugs out. If to much liquid gets in to the cylinder then you reinstall a plug it can cause hydrolock. Not a good thing. A squirt or two will be fine though. Go slow when removing them. If they're stuck don't jam your ratchet, apply slow steady pressure to try and break it free. When reinstalling coat the threads with never seize so that next time they'll come right out.
One more thing. To tell if they stripped as you pulled them out, look at the threads of the old plug. You'll see the aluminum in between the threads of the plug if you did in fact strip the hole.
