acolic
Are you saying that the front end from a Gen 2 or 3 is a straight bolt on for a Gen 1?
I added some LED strip lights under the hood.
Super bright. I'm a little concerned about how well the provided foam double sided sticky tape will hold up to the heat being located right above the radiator. I guess time will tell.
But I need to figure out a switch. I thought I was being smart by tapping into the power for the factory underhood light- but the strip lights remained on with the hood shut. I didn't notice until I was shutting the hood that the factory light flickers as the hood is closed and I figured there must be a position (angle) based switch in the light housing.
I been on here awhile now 2 years or so and this is the first time I came across your thread Tom.I added some LED strip lights under the hood.
We used to have unbelievable radiator failures on our Ford crown Vic's back when I worked with the Taxi company about 11 years back. Our service manager had a stack 15 high with old ones that leaked. I asked him what brands he tried? He said all of them including from Ford themselves. Apparently the Ford, and Mercurys that we had back around 2005-2008 had big time problems. Personally I think it was a mounting/ support issue, but he had his crew just keep throwing in one after another. Tom let us know how the other brand your installing holds up, if you do go that route. You could spring some big bucks and put in something top shelf like Ron Woods, or equivalent, but that's big Dinero!
