Hey Studabaker, thought we lost you! Your comment on 2 wheel drive models the selection controls the front differential somehow. That doesn't make sense, because 2 wheel drives don't have but a rear differential! I think you meant the setting of the switch makes a difference. Your Suv should never be in 4 wheel high or low, unless off road, or plowing through snow. Doing so will burn up your differential quicker than you can imagine. Your closer to Lake Tahoe than I am, maybe try it out in the snow. That axle clip makes sense, replace at once if you haven't yet. Ever seen a car at the drag strip that used a conventional axle without the clip to hold axle. I saw one guy that his axle and wheel came out 2 feet from the wheel well. Scary. Sounds like your getting closer to a drivable, quiet vehicle. Your Suv is one year newer than mine, so like mine it has awd. Change that clip, let us know how it turns out.
