new member , FOREScan help needed
mdax21974
South Carolina
hello, i'm new to this forum,, i need HELP !!!
i recently installed forscan, got the elm 327, what i thought was the correct spreadsheet,and attempted to enable bambi mode on my 2018 ford expedition limited.i went to BCM/726-11-01 changed the fourth value in the first collum to 2.
then cycled the acc. button.
then all sorts of stuff came on. the big wrench on the screen, vehicle collision fault, park assist fault , etc.
truck runs , just got all kinds of codes and faults .. is there anyone that can help me get the original value for that code ?
i did hit save original set up configuration, but i can't find it now. or really know where to get it.
no , i'm not experienced in this , i did watch a lot of videos and had so called spreadsheet.
i did everything on my 2016 f150 and all was fine . any help would be greatly appreciated !!
JUST4FUN
Admin
Moderator Administrator
Il
Moved for better help
LokiWolf
Moderator
Richmond VA
Sorry, did not see this before. @turtle019 nailed it. Gotta use the Ford Asbuilt data.
A few things to remember.
1) ALWAYS....One more time, ALWAYS backup the module using FORSCAN before making a change. You really only need to do this the first time if you are lazy, because having the config your came with stock, you can always get back to there.
2) Use the drop down configs instead of line coding. Bambi is simply Fogs on with High beams. There is also Lows on with High beams. Make those 2 drop down changes, and hit apply. If weird things happen, you reverse it. SO MUCH Safer vs line coding changes.
Good Luck.
