ok go inside to the fuse block test for voltage at the main power lead it should be on the left side of the fuse block big red wire. if you can't get to it then check for voltage to fuse #10 and #12 neg lead on a body ground
if you do not have voltage then make up a jumper lead from the neg battery terminal to reach to the fuse block then hook up the meter to that neg jumper and then use the pos test lead to check the fuses mentioned above
Roxy - I will try and advise the results.... thanks for the trouble shooting tip. I will try tonight.
