AM0608
I turned on my 2000 Expedition 4.6L this morning and it started fine like usual, then I put it in reverse to get out of my driveway and it stalled. I put it into park and tried yet again to start it, it made the cranking noise to start but never actually started and just kept cranking even if I turned the key back, removed the key, etc. I had to disconnect the battery to get it to stop. I posted about this problem in a Facebook Expedition group and it was suggested that it might be the ignition switch or to try using different keys. The key fix didn't work so I went to get the ignition switch and replaced it. I started it about 5 times in a row to test it and it was fine again in my driveway. I posted a thanks and thought that was it. A little later I needed to go run errands so I started it and it was fine even when reversing unlike in the morning. I got to a main intersection not even 5 minutes away from my house and it died while I was stopped and going to make a turn once the light turned green. I started it again and it just started doing the cranking again (the theft light went on as well). It kept doing that for a minute or so then I finally got it to start but as soon as I put it in gear to try to move it it stalled again. It then did the cranking non-stop once again until the battery died. I got towed home and charged the battery (which the charger's overload light came on and the battery was warm). It wouldn't start after charging it so we jumped it and for the first few times it would start but as soon as you remove the jumper cables it would stall after about 30 seconds of it in gear. Tried testing it by unlocking with the unlock buttons on the vehicle and on the fob to see if that helped but didn't seem to, once the battery had more power it would just start the non-stop cranking again. Anyone know what this is (I'm assuming some kind of electrical issue) and/or how to test/fix the problem so we can be reassured of the reliability of it when we want to take it out again? Thanks.
