Not starting, not the battery.
Jack 3322
Norco CA
I'm going to upload a video. People keep saying its the alternator, but wouldn't it turn on then die if that was the case? If someone could link a tutorial for checking fuses, and also the starter. I already bought a new battery and I don't want to buy a new alternator and find out its still not the problem.
toomanytoys
If the truck isn't cranking it could be the starter, starter relay, starter cable or the shift tube. Easy way to find out is to remove the power distribution cover that's on the firewall next to the battery and arc the starter terminals. If the truck cranks then it's not the starter
Bedrck47
Elizebethtown, PA
Back in Dec 2016 you came on this forum asking for help.
You were asked to post the codes and also advised that the hose you asked about was for the washers.
That was the only time that you came on that thread. And you couldn't even take the time to post a update or to say thanks.
You also were asked to give the year of the expy.
So why should I take the time to try and help you when you most likely will just disappear again?
Bedrck47
Elizebethtown, PA
After watching your video I would advise you to read post #2 Yes your ****** Get some gas and a match
J
Jack 3322
Norco CA
Bedrck47 if you are just going to troll and be salty please leave. I'm actually very stressed out here. while others on this forum are attempting to be helpful you are acting like a 13 year old with internet access please fly away.
Bedrck47
Elizebethtown, PA
Sorry if the truth offended you. Your video say a 2000 expy BUT your profile shows a 2001 expy
I can totally understand why your very stressed. Your video shows you have no idea what your doing.
J
Jack 3322
Norco CA
Toomanytoms and Tom the explorer how would I go about arcing the relay. I found a few tutorials on changing it.
Bedrck47
Elizebethtown, PA
You can put me at the top of that your threat list and don't waste your time pinging my address JUSY ASK Talk and threats are cheep and just proves to your personality
J
Jack 3322
Norco CA
I just set bedrck47 to ignore. Since mod won't just delete his posts
