Retros work and cost less than $400 if you do the work yourself. Get a threaded shaft projector and it's easy stuff!
Lots of options on eBay. Most people are going to say these are junk and they probably are compared to a retrofit with high end components but in your situation this should get you better light than you currently have. I did a search on eBay for 2009 Ford Expedition projector headlights and this is what I turned up:Thanks- I think I just have reflectors. I tried the morimoto 9008/H13 kit & ballast and all that BS- won't waste that money again- already did the retrofit source for that attempt. I don't know what I'm doing and don't have the time, so I definitely just want to go plug&play with the whole headlight- not individual pieces. With that being said, what site sells the complete package where I don't have to go into replacing the bulbs, but I can just unscrew the entire assembly and swap in a new assembly?
Bwahaha, preach brother!This is what I feel like around here
This is actually the owner of bullseye retrofits
You guys that say a projector retrofit is the ONLY way to go crack me up (somebody has to say it). A properly aimed reflector w/HID's is just fine.
Let the flaming begin!
I bought this set of projectors for my explorer. I haven't gotten to install them yet, but they were pretty well recommended outside of amazon's reviews. I've used other iJDMToy products before and they seem to be pretty good quality.
I'm also going to be installing these LEDs that were designed for use in projectors. If they don't perform well, I'll get a full HID kit, but this was the cheapest plug-and-play solution.
Ok, so you're one of the possibly dozen people that took the time to properly aim their HID-in-reflector setups. Congratulations.
The raw light output is not the only issue there. You're losing a lot of the effective beam of the HID to ground that you can't see through the hood (though it's still an improvement over stock halogens, I'm sure). The projectors with the cutoff allow you to put the most effective light further away from you, while providing the cutoff that doesn't blind other drivers. Also, once you aim the housing low enough to not be a ******* to other drivers with your lowbeams, you've effectively lost your highbeams since they are in the same housing and now aimed a ton lower than stock. A projector retrofit lets you keep the stock high-beam aim point.
I ran HIDs in my 05 reflector headlights and had no problems what-so-ever. They were aimed so they didn't blind anyone and they shot the light pretty far out compared to the halogens.Retrofitting an 07 Expy? C'mon! Pay ME to retrofit my 12 Expy with projectors and I'll do it. You guys that say a projector retrofit is the ONLY way to go crack me up (somebody has to say it). A properly aimed reflector w/HID's is just fine. I do not have issues with oncoming drivers flashing me as I took the time to properly aim them.
I've got 55W 5000K HID's in both my hi/lows as well as my foglights. I have my foglights wired to stay on when my hibeams are on. On a dark country road they are awesome!
Also, you should reconsider having the fogs stay on with your high beams - it has to do with foreground light making your pupils constrict, and that hurts your distance vision at night. It seem counterintuitive that less light = better vision, but that's a big part of the reason the fogs turn off with the high beams.
Last time I made the same argument I was asked if I was an optometrist... . it's a very simple idea. Your eyes contract with more light, fog lights add more foreground that your eyes detect. This shrinks (contract) your pupils and allowing in less light. This makes it harder to see at night.Yep. This is why fog lights are actually detrimental in most cases. Lighting up the road directly in front of you is only useful in a handful of situations, which is why they aren't just on all the time, and why your headlights are meticulously aimed down the road a ways.
That's not quite right. Your pupils contract with light and dilate with darkness. That's why when you are in a dark room and someone turns on the light you squint because your pupils are too open and it takes a second for them to adjust. So by having bright light your pupils contract, which lets in less light. It is also why you get blinded with somebody with bright lights because your pupils contract and then when they pass your pupils are too small to allow you to see until the dilate again.Last time I made the same argument I was asked if I was an optometrist... . it's a very simple idea. Your eyes dilate with more light, fog lights add more foreground that your eyes detect. This shrinks (dialated) your pupils and allowing in less light. This makes it harder to see at night.
Duh... Yeah I know that and just blew my argument.... But I'm not an optometrist...That's not quite right. Your pupils contract with light and dilate with darkness. That's why when you are in a dark room and someone turns on the light you squint because your pupils are too open and it takes a second for them to adjust. So by having bright light your pupils contract, which lets in less light. It is also why you get blinded with somebody with bright lights because your pupils contract and then when they pass your pupils are too small to allow you to see until the dilate again.
