HardTrance9
Hello all,
For the first time since 2008, I got a strange error code...
P1636 - Inductive Signature Chip Communication Error
How do you fix this? Have a ford expedition 2000. Car starting choking after first having what it seemed a leak on the anti coolant recipient. Had to add water as the oil and temp gauge would raise (couldn't take it to a mechanic for a few days but needed to use the truck for work, normal drive). With water it went ok but then the "trembling" (as if losing power + little chokes) thing started and then got this P1636 code. No idea what to do. One day the car just turned off while in the highway. Could turn it on again but it was strange (and keeps trembling). Sometimes is now hard to start as when you don't have enough gas. Ignition ok but it took me like 4-5 tries.. first time on this too in the morning.. then all normal again.
Last, today late afternoon while on the highway, got like 2 strong "choking" "pulling" moments and then the truck was "normal"... When you speed up, it is as if this error goes away, but you can tell the engine/truck still feels "nervous"..
Does any one know how can I get rid of this?
I read other places that has to do with the PCM, and maybe reflashing it would work and that only at the Dealer you can do this, etc., but have no idea if this is the only option.
Any help, would be greatly appreciated.
NOTE: I don't live near a dealer (2 hour road). Where I leave is a small town of around 3,000 people. Everything is kind of limited around here. With other used cars I had, I would have to order everything online to get the parts and then explain to the mechanics as I could how more less to fix the problem.
If this error P1636 is more complicated, just let me know to plan as I can on what can I do without the truck for a while or so.
Have a great evening!
Hex
Hex
