Park brake light stays on - pedal returns ok and i can FEEL it release on a hill
Adieu
SoCal
Also, normal brakes behave normally, brake fluid level correct
Ideas?
Does anything stand out / look wrong? There IS some weird green connector that appears unused, but no sign of anything that was plugged into it
A
Adieu
SoCal
2012 gator, same park brake system as 3rd gen expy
Chime sounds and dash warning about brake on as well
A
Adieu
SoCal
Btw happened after changing air filter, anything i could have knocked loose there?
A
Adieu
SoCal
RESOLVED : n/m, i somehow kicked loose the rubber stopper on the pedal that engages the park brake light switch
LRNAD90
Maryland
Wow, why doesn't Ford paint or coat any of the in-dash/Under dash brackets with anything. So much rust/corrosion, and you are in So California?!? Wonder what it would look like in a state that has constant high humidity and Winter Weather..
jeff kushner
North of Annapolis
You and I are both in MD....plenty of humidity.....no worry. You might be making a mountain out of a molehill to worry re; corrosion
Not sure what you are trying to learn but good luck!
