Part identification
effingpot
Hampshire, England
Hi - I need to replace a part and order it from the USA to ship here to the UK and want to ensure I am ordering the correct thing. Any help would be appreciated - I looked on rockauto but can't find the right thing.
It's basically the rubber elbow joint on the pcv/breather valve (whatever that means) which comes from the top of the rocker cover.
Here are a couple of photos that show the part which has worn and is leaking!
thanks
Mike
Bedrck47
Elizebethtown, PA
Check rock auto again
PCV (Positive Crankcase Ventilation) Hose
MOTORCRAFT KCV225 {#2L3Z6A664A, 2L3Z6A664AA, KCV126
That is what you need It may look slightly different as that part has the insulating cover on it
It goes from the PCV valve to the rear of the throttle body
effingpot
effingpot
Hampshire, England
Wow thank you - so the part I ringed in red in my photo is just the far right hand part in the photo on Rockauto you think?
I was imagining I could get just the elbow joint but looks like I need the host too - no bad thing I guess.
thanks again
Rgds
Mike
Bedrck47
Elizebethtown, PA
while your waiting for the part you could get some high temp rubber electrical tape and wrap the elbow this should stop the leak and just be a temporary fix
