Thanks, I checked ebay and found the whole switch assembly for $20 new, I might just try that and go from there. Surprising you've had to replace it so many times especially buying new ones. I've never needed wiring diagrams before but I would give it a shot.
The passenger window rolls up and down really slow, this is probably a separate issue not related to the switch? The controls from the drivers side worked fine when I bought the car but the window was always slow. Then after a couple months when I would try to roll the window down from the drivers side it would move slightly (maybe 1/8 inch) but no more. Thats why I thought maybe it was a dead motor. But I'll go ahead and check the switch and if that doesn't work then I'll look into replacing the motor.
