Police Expo Owners
Discussion in 'General Discussion' started by BakerEdition, Oct 21, 2011.
Was your Expedition used as Police or Government
  1. Generation -1
    32.2%
  2. Generation -2
    27.1%
  3. Generation -3 to Present
    40.7%
  1. Adieu
    Adieu Full Access Members
    33
    3,382
    673
    Dec 22, 2016
    SoCal
    I wouldn't trust ANY odometer figures out a country as poor as Jamaica
  2. Yager
    Yager Active Member
    29
    36
    Jun 17, 2019
    Florida
    Lol the truck is clean. Stupid clean. Carfax matched all records and services. I don't doubt for a second that the mileage is true. I did valve cover gaskets when i first got it and the motor was super clean. No sludge and doesn't use oil between changes. I do my homework before buying anything. Work on All my own stuff always.
  3. Anubis
    Anubis Member
    55
    19
    Feb 22, 2019
    The Gorge
    No the lights don't come on either way. Headlights are messed up too, one is on high beam all the time.
  4. joethefordguy
    joethefordguy Full Access Members
    107
    16
    Apr 10, 2017
    almost any VIN translator, such as https://www.northamericanmotoring.com/forums/vindecoder.php?vin=2FTPX17ZX3CA03375 will run it for you. an actual police, etc., vehicle will come back as an SSV. Mine returns as:
    STYLE: 5.4L Special Service 4WD.
    TRIM: Special Service
  5. KBL3
    KBL3 New Member
    Jul 6, 2019
    PA
    The vehicle more than likely had a headlight flasher (wig-wag) unit that was cut out. Some were spliced near the bulb plug, and others had a jumper plug from the flasher that plugged between factory wiring and the headlight bulb. Look for non factory wiring that was cut. Whelen and Federal Signal have online wiring diagrams for their headlight flashers that will show how to return to civilian service.
    Adieu likes this.
  6. plumcolr
    plumcolr Full Access Members
    75
    20
    Mar 11, 2015
    freehold nj
    My 06 was a former police expedition, other than oil changes their maintenance sucked.
    City of Philadelphia.
  7. joethefordguy
    107
    16
    Apr 10, 2017
    I've got the 04 police package. can anyone tell me how the police package 5.4L 2V differs from the "normal" engine?
    thanks
    jg
  8. Trainmaster
    Trainmaster Old School Member
    53
    1,477
    661
    Jun 17, 2017
    Rockaway Beach, NY
    Engine's the same as a regular Expedition. The rear end should have the higher of the two available gear ratios. You may have a larger alternator and battery. Bigger radiator and trans cooler perhaps. Probably a column shifter too.
    Beware that a flaw in Ford's VIN system identifies many cars as SSV's which were not.
    Look for an 04 SSV brochure on-line and it will list the SSV package's exclusive features.
  9. Adieu
    33
    3,382
    673
    Dec 22, 2016
    SoCal
    That's interesting
    I never did figure out how to get back High Beams on my SSV, but never realized others have had the same problem
    For me engaging high beams kills all illumination instead
Share This Page
