Price check - 2001 4x4 XLT
71Rcode
DFW Texas
What do you guys think? I'm thinking I should jump on it for $5k. Wanted opinions from the experts! And this is the same one I've been toying around with for a week now on this forum in one other post about "rust". I've got detailed plusses and minuses below.
2001 XLT 4X4 with 110k (verified mileage)
  • 3 owners + originally a lease (autocheck/carfax verfied this) - last owner had since 2004
  • Cloth interior (8 out of 10 condition) with a 6-disc changer)
  • Exterior paint (8 out of 10) with glossy paint
  • New tires Brigestone tires
  • Nice book of receipts of all work done in past five years
  • Runs and drives well. Good temp and oil pressure, braking and cornering. No suspension noise or bounciness. No warning lights, etc.
Positives:
  • New plugs and all new coils at 100k
  • No coolant leaks at 90 degree elbow (on #2 / #4)
  • No engine/tranny leaks or leaks from the oil filter lines/hoses
  • No engine ticking
  • No tire squat (newer ball joints)
  • Good sway bar bushings
  • Cold a/c - recently serviced (replaced a leaking 2-piece hose)
  • No apparent water leaks from the windshield
  • No rust on the underside of the doors, radiator support, quarters, wheel wells, rocker panels, etc.
  • No door ajar warning lights
  • Has the "E" code transmission
  • 4 wheel drive (high and low) engage like it should
  • No torque converter whine
  • New evaporator cannister under rear LH side of truck
  • 5w 20 valvoline high mileage oil changed every 3k miles
  • Differential, transmission and transfer case fluids changed as scheduled
  • New throttle sensor
  • All window regulators are good to go / windows all work
Negatives:
  • Noticed an exhaust manifold stud broken off / surface rust in this area
  • Original shocks
  • Odometer is flickering off and on
  • Yellowed headlamps
  • Surface rust on the undercarriage sheet metal and frame (driveshaft, differential, axle, trailing arms, suspension, etc. from being in Colorado for the first year of it's life)
  • K&N filter (negative?)
  • Slight oxidation on the rims
For what it's worth, I'm a total DIYer with no time due to kid sports. But I guarantee you I'll wire wheel all that surface rust off under the truck and reshoot it in the first month! Worth the money?
catmandu
Sierra Nevada
Sounds about right with the book of receipts and new tires.
If it were me, another pressed for time DIY'er, I'd not worry about surface rust as it should not get worse in the southwest. New headlamps are under $50 on eBay and take no more than 15 minutes to swap out. Put KYB shocks on mine pretty easily for a decent price, and they work! Manifold stud easy to deal with if you have access to a TIG welder (weld a washer to the stud, then a nut to the washer, back out the stud and replace). Skip the odometer until you have a second reason to take the dash apart (or the kids are in college).
JMHO
sgtowing
Supporting Members
Valrico, Fl
I would say go for it. The surface rust is not a big deal especially if your going to keep it in the southwest and all the other negatives are minor except for the exhaust stud.
71Rcode
71Rcode
DFW Texas
Thanks for the responses, guys. I've got a quart of PPG gray-tinted epoxy primer that I'll use on the undercarriage once I wire brush all that rust off. Call me crazy...but it's the old Mustang restorer in me. I guess as long as the exhaust manifolds aren't leaking, that stud should be fine. I may get a wild hair and try to remove it.. don't want to make things worse. I will probably try sanding and buffing the headlamps to see if I can get the yellow out. I've done this successfully before but not with a Ford...should be a piece of cake. KYB shocks is not a bad idea. I'll probably do that when I have it up on jackstands when I'm getting ready to reshoot the undercarriage. Makes sense to do it then.
Is the speedo cluster that difficult to remove from the dash? The soldering part should be simple.
Thanks, guys. I'm going to go for it!
Jay87LX
Cleveland oh
I did my speedo cluster last week- no problem at all- there is a trick to get the headlight switch out- be sure to find the vid on Youtube
rtbrjason
Rochester, NY
If it helps, I just paid $4250 for a 99 with 127k miles. It's got the 4R100 and 3.73 gears, Tow package, rear seat etc. It's been in upstate NY the past 3 years so there is plenty of rust underneath. The body is so far rust free which wasn't the case with any of the other 6-8 expeditions I looked at. It's an Eddie Bauer, with really beat up front seats and was really dirty in general. It cleaned up fairly nice and only needs new front seats/covers and a few dash pieces to be like new inside.
I don't think I got a great deal and would rather have paid less but with no body rust I decided I would go $4k. The guy wouldn't budge from $4250 so I paid it. I've since dropped about $200 on it for all new fluids, wipers, fuel filter, pcv, trans kit, air filter and misc. It seems to have a valve cover leak so will need to do that and probably all new plugs and cops. At that point I hope to have a long term second vehicle out of it.
Newport News, VA
Negatives:
  • i wouldnt worry about it
    change them
  • Original shocks
    bothers me
    change out
    not worried
    put one on
    no biggie...you can find them on ebay/craigslist or buy some new ones
i updated my comments in the quote
71Rcode
71Rcode
DFW Texas
Thanks again, everyone. I'll check youtube for that headlight switch removal.
Good comparison on the your '99 -- thanks. Sounds like a nice truck for sure. I want to say this one has the 3.73s etc. Need to check the door tag on it to verify the trac loc/limited slip. You should check out all the seat cover suppliers on ebay... there are some pretty low cost options available for us. It would be good to know if someone on the board tried this (slip on covers - leatherette, for example).
Sounds like you're doing a lot of great preventative maintenance. Very cool...that is my thing, for sure. I may do some of the things you mentioned (some have been done recently by the owner) and also change the 02 sensors. Need to price them out... don't want to sink too much money into the truck if I don't need to.
And thanks for the point-by-point comments on the "negatives" I listed. All much appreciated. I'll see how she rides before changing out the shocks, for sure. But those are easy. Does the odometer bother you becasue of the difficulty of pulling the cluster or that it could mean something is awry with the expedition? His mileage all ads up according the autocheck report. I can do the headlight polish for free (have all the materials) - so I'll try that out before buying new ones. TRYING TO KEEP MY SPEND DOWN ON THIS BAD BOY! The engine compartment detail and undercarriage redo is the car restoration side of me. Check out this car I just finished and sold - going to Luxembourg. Check it out. 1973 Mustang Convertible
The expi has a K&N filter in the stock housing. Just wondering if you guys thought it was a negative? The wheels are 5 footers, for sure. Not bad. Just noticable when you get up on 'em.
Jay87LX
Cleveland oh
I am 99% sure it has LS. The odo will be a breeze, I doubt there is anything foul going on- Just go ahead and buy it and start to enjoy-lol
71Rcode
71Rcode
DFW Texas
Just bought it. Will have pix etc. in the coming days. Felt great on the 30 mile drive home!
71Rcode
71Rcode
DFW Texas
Didn't take long, guys, before I tore into it / started ordering parts. I've had for less than 48 hours :buttkick: Somebody kick me.
Ordered:
  • Husky front and rear floor mats (and rear cargo area)
  • New headlights (old ones were yellowed)
  • Getting ready to order Moog tie rod ends, front sway bar links (mine are shot) and shocks. Trying to figure out whether to go with Bilstein ($$) or a cheaper Monroe. Let me know what you guys have done
Projects complete:
  • Odometer fix complete this morning
  • Washed and somewhat detailed the engine compartment -- more to do, here
  • Sanded down the surface rust on the frame in the front wheel wells and suspension, shot with PPG epoxy primer and then hit with a cast colored paint
Projects in the coming weeks:
  • Replace shocks - any recommendations?
  • Replace tie rod ends and front swaybar links
  • Have the front end aligned
  • Spray the front mesh grill, install the new headlights and put the chrome grill back on (this morning I pulled the front grille chrome and grill (to remove the headlights) and prepped the grill (mesh) for paint this week)
71Rcode
71Rcode
DFW Texas
Hey everyone, I just wanted to report back on things.
  • It has an open rear end. Bummer! Weighing my options on whether to spring for the traction lock (trac-lok) differential. Replacing it requires you need to also replace the differential carrier bearings and races and need shim kit. So the money for this swap, if I go retail for the carrier, the bearing/install kit and the install cost could be $1000...which isn't worth it to me. My other option is to do it on the cheap with the help of a friend using all used components. Here is the thread I started on this: http://www.expeditionforum.com/f42/traction-lok-application-question-17657/
  • New headlamps and reshot the grill: I replaced the OEM plastic headlights with a pair I found on e-bay for $35 shipped. They came with new bulbs, too! This was somewhat of a PITA, replacing these, as the "sliding brackets" that you need to slide to pull the headlights out were kinda "dirt rusted" to where they wouldn't move. I ended up pulling the grille out and reshooting the center grill plastic --- looks awesome now --- and the turn signal bezels to get the headlights out. My two hints on the headlight replacement are these: (1) put axle grease on the little rubber "nubs/nibs/ends" that press into those sliding brackets, to keep them from "seizing" in place when you remove the headlight for adjustment (2) lube the locking brackets so they slide up and down easier (3) make sure you orient the headlight bulb in the right direction! I had mine upsideown and couldn't figure out why my bright lights were weaker than the standard HD setting.
  • Removed the wiper arms (front and rear) and the plastic trim that goes under the windshield and reshot them gloss black and semi-flat black respectively.
Will eventually prep and reshoot the outside front mirrors to freshen them up and remove and paint the wheel well faded black plastic. Hope to have some pix soon for you guys. This has been a lot of fun and I am enjoying using my classic mustang restoration skills to freshen up the Expedition. :buttkick: Somebody kick me for being an idiot...
