stamp11127
Yes that is it.
Do you know how to make a jumper wire?
Battery Junction Box in engine bay(left side)
Fuse 10 is a 20amp fuse - should have power on both test points. If it does then:
Remove fuel pump relay, jump #30 and #87 with the jumper wire.
Try and start engine.
If it runs you will need to remove the fuse or jumper wire every time you shut off the engine or the battery will be discharged.
This may or may not work. Did you try using a different key?Hi guys,
I have a 01 Expedition and changed out the stock bulbs for LEDs. I did have to solder a couple as they didn't fit as tightly as they should. Went to put the cluster back in and crank it. Cranked and started then died. Now it just turns over. Any ideas? Thanks ahead of time cause you guys are the BEST!!!
Also, this is my only ride so I gotta figure this out!
I have no way to check fuel pressure. I am stranded at my home.
