Kurtyg2020
I have a question for you guys, I have a 16 Limited and I ran it through the car wash this morning, and when I got to work I noticed the ice build up on the outside of the rear doors and the running boards. I am obviously having issues with the door draining, and I mentioned in another thread both of my rear doors have a tendency to retain water. I have not had time to really dive in a climb around on my back in inspect the doors. My question is are any other members having this issue? My front doors are not having this issue, so I assume it has something to do with the door drains. Does anyone have any tips or tricks on how to check to see what the issue could be. I would guess that the door should drain quickly and it is not, or do I have any issue with getting to much water into my door and the drain is not designed to remove that much water. I want to get this correct so that I don't have water in there during the winter and it freezes in there and expands and causes all sorts of other issues.
Thanks in advance.
Thanks in advance.
