Rear hatch rattle
texevora
DFW
I have a super annoying rattle coming from the rear hatch that occurs anytime i go over high frequency bumps on the road.
I was able to get the rattle to go away a few times by successively adjusting/tightening the window latch (the rectangular latch with a hex nut adjuster), however the latch is now so tight that it barely shuts, and the rattle has returned with a vengeance.
I am guessing it is coming from something inside the plastic rear hatch cover. Has anyone experienced these rattles and been able to address them once and for all? Any tips/guidance would be greatly appreciated.
99WhiteC5Coupe
Are you sure the rattle is from the hatch?
Do you have a sunroof / vista roof? If so, there were several TSB’s issued by Ford to correct a rattle (which may be mistaken for a hatch rattle).
Hardrocker
Colorado
Resurrecting this old post because I have/had the same rattle. Went through a thorough investigation to confirm the source. With the help of the OP's results, I decided to do the opposite. I loosened the window latch half a turn. I figured that the latch was scraping against the locker in the door. See the wear marks on the latch. So far this has been successful and the rattle is completely gone. If it comes back, I will update.
Deadman
Wisconsin
Mine was the rear cargo floor squeaking on the metal underneath it. They removed it and resealed it.
Bonk
mke
Bunch of stuff rattling around under cargo cover for me. Cut up a rubberized carpet floor mat. Tossed everything back in and good to go now.
badfish
HTown
Glad I saw this! I had a persistent rattle on bumps on city roads. Loosened the latch nut as much as I could and put it back on and problem fixed!
I also had a dealer plate cover with only two holes for screws which was was banging around like crazy. Drilled two additional holes in the cover and reinstalled with four screws and that went away as well.
Hardrocker
Colorado
The rattle did eventually come back. I went through the same process again and it went away - for a while. So I decided I needed a different solution. I bought some kevlar tape off Amazon. It was less than $10 for like 100 feet 25 meters of tape. I used about a square inch and wrapped it around the end of the latch. It's been over a month and the tape is still there and no rattle.
Edit: the tape roll I bought was 25 meters.
