Deadman
EXACTLY!Just installed Hellwig front and rear sway bars last weekend on our 2017 EL Limited.
Made a huge difference on leaning when cornering ... and the side-to-side sway issue when going thru approaches.
Did you order from Hellwig? I ordered from Suspension Connection...it was a bit cheaper.. but not sure WTH is going on if they gave you a ship date.. [emoji848]
Ordered mine from Suspension connection. 8 week lead time and when 8 weeks came, they said back ordered another 4 weeks. Cancelled order. Reordered from Summit Racing. Got front sway bar in two weeks and rear in 3 1/2 weeks. Suspension Connection sucks. They are actually Tuff Country, which I did not know until the refund BS I went thru. Had I known this I would never have ordered from them. Had to remove and return their crappy leveling kit on my 2019 Duramax. Do yourself a favor and stay away from Tuff Country. Which is sadly a Salt Lake City, UT business where I currently reside.
Sent from my iPhone
As an engineer myself, I understand there is a give and take. They should simply design the sway bar to be adjustable so those who want less sway, but are willing to give up some ride comfort, can make that decision ... without purchasing aftermarket parts to adjust the sway bar stiffness.EXACTLY!
How exactly do you take a bar that twists at a specific rate and poundage and make that twist adjustable? The sway bar is borrowing spring rate from the other side.
They do make a duel rate sway bar for off roading. Full locked, full open and somewhere in between. Uses air or electric pressure plates. Kinda like our E rear diffs works. But they basically have tried to stiffen the ride in Sport with the shock dampening. Ford should have the option to just change the shock settings without changing the throttle and Trans mapping.
I FINALLY got to take my Expedition on the same 1,200 mile road trip that I've taken it on BEFORE the sway bars were swapped. Its an absolute HUGE improvement in handling and ride. When it was stock, it would buck all over the place when I crossed brides and stuff at 85mph and it almost wanted to wander into the other lanes because it was flopping all over the place with the sloppy suspension. Now, it feels a lot more like a controlled performance sedan does. On same bridges, it now just goes up a small amount and immediately comes down and is settled right away. Before it would bob up and down 3-4 times and make you hold on for dear life if it was in a corner.
I never used to run it very hard simply because I had little confidence in its handling. On this trip I found myself really hammering down on it hard because it felt so planted and in control. Its hard to put a price on handling and control, but if I had to do this over again for double the price, I'd still say its money well spent.
I can't believe how Ford sent these out handling so horribly and that there aren't more people rolling them over or whatever from it. I mean it was ok before, but its literally like driving a completely different car now. It will flat out run circles around my 18 Navigator L Black Label on rough roads or corners.
If you are on the fence about the handling of your expedition, just get the sway bars and you will be happy beyond words if you like it to handle like a performance sedan. Thats really the best explanation I have for it......
This trip netted 2 mpg less, because I was ON the throttle ALL the time! lol. I used to drive it like an old man, because it seemed necessary!
