Rear view mirror vibration
Bilal
Uae
Has anyone experienced the rear view to be shaky on slightest of bumps.
Any hacks, fixes, suggestions would be welcome.
Hamfisted
Ft Lauderdale
The cast aluminum base has a metal piece inside that works loose. You can either replace the entire mirror or there's a jerry rig way to put tension back on that internal metal piece to make it more secure to the steel mount ( mirror button ...) that's glued onto the windshield.
Rear View Mirror Button Release Tool
Bilal
Bilal
Uae
Ended up ruining my windshield. Tried to get it off without using the proper tool, instead tried with an allen key (another youtube video!!).
Had the rear view mirror moved aside a bit at a glass store. The guy put epoxy in the moving bit so now at least the vision isnt blurred, but a couple of hundred $$ will be down the drain.
