Roof Rails Care
cubsfanfordman
On my 2013 Expedition, the roof rails seem like they are hard plastic, or maybe some kind of textured aluminum. How should I care for them? Wax them or use a polymer sealant, or are they really plastic or plastic covered and need something like Armor All?
BAD RONALD
Fairfield CT
I can only speak for the rails on my '01. They are aluminum and the paint failed. I use a rooftop carrier from time to time but do not think that to be the cause of the problem. Simply put, Ford famously does not know how to paint aluminum.
When I decided to refinish the rails I opted to use pick up truck bed liner. One aerosol can was enough for the job. When I was at the auto parts store, the guy behind me in line offered great advice on painting aluminum. For prepping the surface to bare metal he recommended scotchbrite abrasive pads. Apparently sandpaper leaves a surface condition on aluminum that is adverse to coating bond. Turns out the guy was a retired Sikorsky Helicopter tech with career experience in aircraft aluminum.
The bedliner worked out great. It has a sanded texture that built up nicely. Cargo stored on the rails doesn't slip around and can't scratch the bedliner. The coating has a factory appearance that still looks great years after I did the job.
I realize that your question was about care and maintenance, but failure of the rail paint might be inevitable on your Expedition.
darmahsd
Wilton, NY
The roof rails on my '05 are plastic. So I'm thinking all future racks remained plastic. I swapped them out for the aluminum sliding rail system of the '97-'02 and '03-'04. The mounting holes in the roof are the same spacing for both. I did this because I have all the roof rack gear for the first type rack and I just don't feel comfortable mounting a ski box to something made out of plastic, going down the road at 75 mph. I'm sure the plastic rack is designed structurally sound for something like this as long as you observe weight limits, but I'm old school and just like metal holding my things up.
