shifter arm 99 xlt
popeye
Ladner B.C. Canada
I noticed the previous owner had taped up the end of the shifter arm so being curious i took the tape off. It seems the plastic weld between the two shifter knob parts had com apart. Whats the best glue/epoxy to use to make a really good weld.
Thanks
spadesluck
New Mexico
I beleive JB weld makes stuff for plastic as well. I have be mistaken, however I would beleive any good plastic glue would work. My only problem with it would be that area is going to go through a lot of abuse grabbing it all the time so no amount of glue/epoxy may work. Might be best to find a junkyard.
jstrut
Grand ledge, Michigan
I had the same issue when I bought my truck. The best thing I have found is some E6000. That stuff bonds almost everything. Beyond that you are probably looking at a two part epoxy if that doesn't hold.
