Steering vibration
Doug Shumway
Riverside ca
Ordered a 2021 XLT FX4 and noticed it has a strange vibration at medium to high speeds when changing lanes. It almost feels like I’m hitting lane bumps but not as prominent. Anyone ever experienced this?
Thanks
Yes I’m going to take it in.
caplanm
Boston
Sounds like it's your lane departure warning which is a 'feature'. Try using the turn signal when you're changing lanes. If the vibration stops, that's it!! You can turn it off with a switch located above the sync screen, and adjust how it operates under settings
Going_Going_Gone
Phoenix
On the other hand, if you signal your lane changes with the turn signals, it will not vibrate while the blinker is on.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
It does it on long sweeper turns as well.
Yes, if you are close to or on the lines.
See if you use the signal or turn it off and it goes away. If it doesn’t, come on back here and give us some more details.
Deadman
Wisconsin
There is assist that can be shut off AND warning that can be shut off. Make sure both are off.
