Stupid Ford Lugnuts!
cooldude919
Missourio
Decided to take care of the infamous ford lug nuts before things got too out of hand. Seller on ebay had 25 pack of Gorilla lugs for $68, i had some ebay bucks set to expire, so ended up only costing $55. I apparently picked the worst wheel first, ended up getting 1 lug stuck in a socket that ill have to work out later. After the first wheel, the rest seemed in better shape plus i had a process down by that point. Money will spent to not have to worry about this issue again!
techdude99
US
I'm new to Ford and glad I saw this post.
Looks like they don't like impacts. Good to know.
C
cooldude919
Missourio
Are they just a chrome cap over a steel nut?
Yes, OEM ones are, i think i read its tin or something. Either way they are 2 piece, water gets in between and they balloon up and then sockets dont fit over them. Going to a good solid 1 piece is the way to go.
C
cooldude919
Missourio
Here is a photo i found on another forum, how bad they can get and what you may have to do to get some off!
mquick5
Buckeye Country
There web site still says there plated. But lifetime guarantee!ae0d9f61f837a77efd9179e025620a2b.jpg
C
cooldude919
Missourio
Chrome plating is different than two piece construction, note it says 1 piece construction in the same picture, the issue with ford's is the two piece construction, not the chrome plating.
C
cooldude919
Missourio
I believe mcgard makes a good 1 piece as well, so Gorilla is not the only option for anyone looking.
mquick5
Buckeye Country
Do you have a link to the ones you purchased? I had mine replaced once at dealer. But they put the same pos ones back on. Recommended driven products, but there like $160 a set, but includes 4 lockers.
