Stupid Ford Lugnuts!
techdude99
US
I have McGuard on another car. 10 years and still going strong.
C
cooldude919
Missourio
Do you have a link to the ones you purchased? I had mine replaced once at dealer. But they put the same pos ones back on. Recommended driven products, but there like $160 a set, but includes 4 lockers.
Here is the link where i got mine, they come loose all in a box, assuming thats how they offer them cheaper. Amazon has some as well, along with summit, etc.
https://www.ebay.com/itm/25-GORILLA...UTS-14X1-5-M14-ACORN-RIMS-CHROME/161049644684
61147cx and 61148cx are the same, one us a bulk pack and one is a blister pack.
mquick5
Buckeye Country
@cooldude919
One more question, does the factory lug wrench fit the new Gorilla nuts? I see it says 21mm socket, but no idea what OEM ones are.
Shaffer9
Ms
I trashed the factory ones at 1500 miles. They weren't as bad as these but definitely had issues. Also went with gorillas.
scottdm
Western PA
OEM are stainless steel cap not chrome.
Gorilla are chrome plated, they might rust (probably will in the salt)
but at least you can get the wheel off
https://www.gorilla-auto.com/lifetime-lug-nuts
Replaced the lugs nuts on a different vehicle with the one piece Gorilla chrome lug nuts due to the same issue. The chrome lug nuts definitely do rust with time in areas with salt on the roads in the winter. They mostly rust on the edges where the socket contacts the nut vs. the flat surfaces. Still better than the hassle of the 2 piece nuts that swell and fall apart.
2018expyXLT4wd
@cooldude919
OEM lug nuts should be 21mm - my nuts were deformed: 13/16, 21mm & 22mm on one wheel. I swapped them all out for McGard 64034 (black 22mm). Get yourself a breaker bar and deep socket (21mm for your Gorilla)
TheDoug
Mansfield, TX
I am glad you posted this... I took one wheel off (only once) to look at something for my upcoming brake install and I looked at the lug and thought holy #$%^. it was all beat up with one go of the impact.
Ordering new ones now!
